Turbo project '92 Firebird V6 3.1
Old Nov 14, 2006 | 12:05 AM
koen92firebird's Avatar
Car: '92 Firebird
Engine: 3.1 V6
I would try build a turbo on my engine. But I don't know anything of a turbo.
So I hope this could with the know how of daves12secV6 and other people.
To daves12secV6
Your turbo runs this on 3 or 6 cylinders? And why have you done this?
Old Nov 14, 2006 | 12:16 AM
daves12secV6's Avatar
the turbo runs off all 6 cyls,if u only run it off 3 the engine will not run right,not to mention it would take forever for the turbo to spool up/kick in.
now if u ran 2 turbos u could run one off 3 cyls and the other turbo off the other 3 cyls
Old Nov 14, 2006 | 12:50 AM
Car: '92 Firebird
Engine: 3.1 V6
Have you pictures of the exhaust manifold, both sides to the turbo?
How you have made it?
Old Nov 14, 2006 | 01:09 AM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
https://www.thirdgen.org/forums/v6/3...ing-turbo.html
Old Nov 14, 2006 | 09:50 AM
Car: '92 Firebird
Engine: 3.1 V6
To daves12secV6
Have you changed your ignition system for the turbo? Or is this still original?
Because the ignition timing is also important for the turbo!
Old Nov 14, 2006 | 02:59 PM
u can run stock iginiton upto 9 psi,but after that the stock stuff becomes to weak.the stock timming curve is very conservative,so u really dont need any kind of timming retard untill u get into higher boost levels.i actually run my current engine at 10 psi with +4 aditional degrees of base timming,though i do aociasionally get some detonation and pinging.if i weree to back it off 2 degress it prolly wouldnt ping/detonate at all.
timming also depends on octane rating as well,the higher the rating the more timming u can run safely
Old Nov 14, 2006 | 04:11 PM
Car: '92 Firebird
Engine: 3.1 V6
Where have you placed the boostcontroller? And have you a maunual or electronic boost?
How many miles have your engine runs since the turbo setup? And have the engine always runs on 10 pounds of boost?
Old Nov 14, 2006 | 04:40 PM
i have a manual boost controller,its mounted under the hood,ive got about 15,000 miles on the engine with the turbo on it,this engine has always run 10 psi
Old Nov 14, 2006 | 06:48 PM
Car: '92 Firebird
Engine: 3.1 V6
Where exact under the hood? And what does it do the boost controller?
Have you maybe some picture?
Old Nov 14, 2006 | 06:50 PM
its mounted nexto the battery it connects to the wastegate and allow u to turn the boost level up or down without changing the springs inside the wastegate,i dont have any pics offhand but i can take some tommorow
Old Nov 14, 2006 | 06:59 PM
Car: '92 Firebird
Engine: 3.1 V6
Yes, I had gladly pictures of the boost controller and the connections. Thankx
Old Nov 15, 2006 | 10:44 AM
Car: '92 Firebird
Engine: 3.1 V6
Have you also the original cylinder head gasket on your engine or have you a copper gasket?
Old Nov 15, 2006 | 10:49 AM
stock gaskets,there is no need for copper4 head gaskets
Old Nov 17, 2006 | 11:59 AM
Car: '92 Firebird
Engine: 3.1 V6
Dave, have you the stock exhaust manifold or headers?
And have you the stock ECU chip or an tuned chip?
Old Nov 17, 2006 | 10:17 PM
i use the stock ecm and chip,but i also run a mass airflow system,since ur car is a 3.1 u have a speed density system,i am unsure of how well it will work with a turbo system in stock form.
i have stock manifolds,though on my new engine im am building foward facing headers
Old Nov 18, 2006 | 08:53 PM
turbo2825psi's Avatar
Car: 1992 RS Camaro
Engine: 5.0 tbi
Axle/Gears: stock 10 bolt 3.08's
dave i was wondering where d u have the maf located?
Old Nov 19, 2006 | 04:59 PM
its mounted on the inlet sude of the turbo,i have a aprox 8inch long tub that goes to the turbo inlet that makes a 45* bend at the end the maf is hooked up there,with an air filter hooked to that.look in my howto thread i belive there are some pics in there
Old Nov 20, 2006 | 01:43 PM
Car: 1992 RS Camaro
Engine: 5.0 tbi
dave on those forward facing headers u got them in the work and also are u gana be selling any?
Old Nov 20, 2006 | 01:45 PM
possibly but there not gonna be cheap
Old Nov 20, 2006 | 01:51 PM
Car: 1992 RS Camaro
Engine: 5.0 tbi
well i was thinking about building some off fwd manifols do you thing that will work. because i wana take a weekend to do my turbo and i dont wana be working on the headers forever
Old Nov 20, 2006 | 04:30 PM
firstfirebird's Avatar
Even with extensive mechanical knowledge, it's quite a project! My mechanic even thinks I'm crazy for putting a turbo on the 6! I have him do all the "DIRTY" work (anything that will pour fluids all over my driveway). The best thing to do is have all the parts handy (even some extras) and a friend to help won't hurt either. I'm still up in the air 'bout the twin turbo setup since I'm running a MAP and not a MAF. If you run a single setup, you can use your factory manifolds and just get a y-pipe from dave.
For all of you, I've found a website that has cheap mendrel bends in all sizes, including header kits and intercooler kits that start around $45 USD.
Here's the link...
http://store.racing-solutions.org/bendkits.html
Here's a link for silicone connectors and clamps...
http://www.roadraceengineering.com/hoseandclamps.htm
Both have lots of goodies that are better quality than e-bay perhaps.
Lookin forward to having someone doing this build at the same time as me!
P.S. Welcome to thidgen!
Old Nov 20, 2006 | 05:02 PM
im unsure of what the fwd manifolds look like,but id have to say the easiest way is to build the under k-member y pipe like i did.its cheap very effective,and dosent require welding to cast iron,which is hard enough in its own,u have to use nirod,and even then its still a bitch to weld
Old Nov 20, 2006 | 05:42 PM
I'ts easier to make a mild steel plate to bolt to the head, welding cast isn't easy even for my friend who works at a CNC machining factory!
Old Nov 21, 2006 | 07:58 AM
Car: 1992 RS Camaro
Engine: 5.0 tbi
well some of the manifolds ive been looking at are mild steel
Old Nov 22, 2006 | 03:24 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Why don't you do this
Old Nov 22, 2006 | 03:28 PM
Car: 1992 RS Camaro
Engine: 5.0 tbi
id love too but way too much money and time for me right now
Old Nov 22, 2006 | 03:58 PM
Car: 1991 Firebird
Engine: 3.1L V6
werd
Old Nov 22, 2006 | 04:39 PM
That's SWEEEET! Got a couple of questions, 1.What size turbos are those (I have a pair of a/r .48 exhaust.63 I was thinking of using)? 2.No wish to use an intercooler? 3. Is that a 3.1 w/ a speed density? 4. Did you build your own manifolds, and how hard were they?
Wouldn't cost any more than your planning to spend now! If you don't use an intercooler, you could use that money to buy another turbo. The major concern would be building the manifolds, but the intake side is simpler.
Last edited by firstfirebird; Nov 22, 2006 at 04:46 PM. Reason: Automerged Doublepost
Old Nov 22, 2006 | 05:43 PM
Car: 1991 Firebird
Engine: 3.1L V6
Haha, calm Firstfirebird. That is not my car or engine. I saw that picture and was very impressed by it so I saved it. If I had the money and knowledge to do that, i'd definetly share it(only the knowledge though).
Old Nov 23, 2006 | 12:38 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
If my memory is right thats not even in a camaro. I doubt if youd have enough room on the sides to mount the turbos there.
Old Nov 23, 2006 | 07:35 PM
Yeah, I got so excited that I wrote that before checking out the pics of YOUR car, haha
BTW, your car is sweet too...
Old Nov 23, 2006 | 07:42 PM
I think there is enough under mine (Firebird). I was hoping to talk to someone about twin turbo. I mean daves12secv6 has been awsome about answering questions, but he's using a MAF setup and I need some answers on a MAP system. Does anybody know if the twins could be run into the intake (before the MAP) or would I have to run the MAP BEFORE the turbo (like daves)? I already have some turbos and the guy who gave them to me is really pushing for the twins (he has a tt300zx). He said I would be the only one around to have them, but now that I saw that pic from charcoalbird I see that SOMEONE has already done it, and I like it!
Old Nov 24, 2006 | 07:39 AM
grimmcs's Avatar
Car: 91 Camaro
You might, I dont know that much about the room that the Firebird has.
The MAP sensor comes out of the back of the upper plenum. Also I just read that you could keep the MAP and stock chip if you ran a FMU.
the_nikfive
Aug 11, 2015 02:46 AM
Ovrclck350
Feb 14, 2008 01:48 AM
Rogue Leader
Jun 16, 2003 07:12 AM
Camaro_hunter_d
Car Audio
37
Jun 30, 2001 09:13 PM
TheKid
Jul 26, 2000 02:50 AM
