Will motor mounts line up??
Old Dec 6, 2006 | 07:56 PM
90 Camaro's Avatar
Car: 1994 Chevy Blazer S10..1990 Camaro
Engine: Blazer - 4.3L..Camaro - 3.1L
I am planning on swapping parts from my damaged 1990 RS to a rolling chassis of a 1987 RS. Will my 3.1 bolt right in or will I have to do modification?
Old Dec 6, 2006 | 08:10 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
I've heard the 3.1 and 2.8 are the same blocks? I would assume that would mean the motor mounts are the same. But I'd get confirmation on that.
Old Dec 7, 2006 | 12:13 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
2.8, 3.1, 3.4 will bolt up in the same place. 3800 II will bolt up also if you make the brackets a certain way
Old Dec 7, 2006 | 06:52 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Old Dec 7, 2006 | 07:25 AM
90 Camaro's Avatar
Ok. Thanks alot for the replies. That helps me out alot!
Old Dec 7, 2006 | 10:41 AM
firstfirebird's Avatar
Isn't the 3.8 a 90 degree?
If it is the tranny won't bolt up.
Sorry answered my own question from Wikipedia Encyclopedia...
"Another oddity of this engine is that although it is a 90° V6 it has the GM 60° V6 bell housing pattern when it is used in FWD or RWD applications (pre-3800 series RWD cylinder blocks incorporated the BOP bellhousing pattern). For use in the RWD applications, the bellhousings on both the manual and automatic transmissions are altered."
BOP is Buick Olds Pontiac for those of you who don't know...
it's amazing what happens when we
Old Dec 7, 2006 | 01:58 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Yes but the question wasnt about the tranny, it was about the motor mounts. Nice try though
Old Dec 7, 2006 | 05:15 PM
I understand that, but project 85 was reffering to a 2nd gen 3.8.
The 1st gen 3.8 will not bolt up to the tranny, hence my comment.
What good would it do if you could bolt it in the car if the tranny didn't line up?
Old Dec 8, 2006 | 03:09 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
it better bolt up!!!.....thats why i got the 3.4!!! lol
Frozer!!!
Jan 19, 2024 04:55 PM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
