stealth ram v6?
Old Dec 14, 2006 | 09:07 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
stealth ram v6?
wow were would u pick u one of these or is it just for show cause it looks way better than the stock intake plenium.
Old Dec 14, 2006 | 09:10 PM
firstfirebird's Avatar
The pic didn't show, make sure it's under 1.0 meg.
I usually reduce the size if I have to.
Old Dec 14, 2006 | 09:13 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
well here's the link that would be easier for those who have a 56k thanks tho man hopefully this works http://www.omnipotent-goku.com/iroc/...bum03/07_G_001 it's one of the thirdgen members pic gallery.
actually there's a good chance that that is a v8 and i mistaked it for a v6 for a minute but it don't look the same it looks kinda smaller than the v8.
Old Dec 14, 2006 | 09:26 PM
No, I don't have 56k! But the link worked. You can also copy/paste, but like I said the pic has to be under 1meg. It sure does look like a 6er, though!
Old Dec 14, 2006 | 09:29 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
that makes it look so much better i hate the look of the regualr ones and love the way the stealth ram looks on a 8 and there's someone who improvised it looks like but how i wounder.
Old Dec 14, 2006 | 09:33 PM
If you read daves12secv6 "engine build pics" thread, you'll see that lots of people make their own, I have no idea if that's something you can buy?!
If you find one, find me and let me know!
Also in his "intake ideas" thread
Last edited by firstfirebird; Dec 14, 2006 at 09:36 PM. Reason: forgot to add ""intake ideas"
Old Dec 14, 2006 | 10:33 PM
To The Top, anyone seen this before? Rover420, you've got me interested now!
Old Dec 14, 2006 | 11:09 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
its a V8 look real close at the dist cap. 4 wires going to the one side of the engine. plus its a V8 radiator. Does seem real small tho.
Edit: that and its a pic from an IROC gallery.
Edit: 5 wires 1 to the coil and 4 sparks
Old Dec 15, 2006 | 09:29 AM
If you look at the next pic of the same car, it's an RS, so it could've been a 6er. My thought was the same at fist glance of the site.
It just seems that there is a lot of room between the radiator and pulleys?!
This could be if it's an autocross car and the engine/tranny were moved back and down to lower the center of gravity.
Good eye though.
Old Dec 15, 2006 | 09:44 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
alt and AC stuff is on the wrong side to be a V6.
Come to think of it unless GM changed things All GM cars have the Alt on the left looking at it. Though 86 is the newest I have owned. Every GM car I have owned V8 or what not, Alt was on the left looking at the engine.
And yep it looks small, could be a ford in there.
Old Dec 15, 2006 | 10:09 AM
Good eye, once again!
Hey Gumby, thanks for the powdercoated throttle body, looks fabulous!
Old Dec 15, 2006 | 11:14 AM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
That's the stock Plenum for a TPI V8.
Old Dec 15, 2006 | 10:47 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
You guys are scaring me.
Nothing about that says V6, except maybe the plastic distributor cover missing from the rear of the intake making it appear shorter.
Old Dec 16, 2006 | 12:07 AM
The only thing that had me confused is the distance from the firewall to the pulley system seemed wide, similar to my car.
Old Dec 16, 2006 | 12:31 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
You guys are kidding me right?
I'm seeing a 305 TBI car that had a TPI conversion with black accel runners, those weird blue hoses and no intake duct installed.
Old Dec 16, 2006 | 08:54 AM
And how do you know it's a 305?! You can tell the difference between the GM smallblocks even though they are the same size externally?!
Old Dec 17, 2006 | 11:04 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I hope you guys that think it's a V6 are joking, that's V8, GM, V8, TPI, either conversion, or factory, but with some aftermarket runners.
Old Dec 17, 2006 | 11:26 PM
Not saying it's a V6, but does the pulleys seem far from the radiator to you?
I looks to me the motor may have been moved back a couple of inches, it's an autocross car. But then again I don't look under the hoods of the V8's too much.
Old Dec 18, 2006 | 12:42 AM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
I'm agreeing with the other guys that say it's a V8 with the TPI intake just different intake runners. It's just missing the distributor cover. As for the spacing it is in the stock location from what I can tell. The angle is misleading in my opinion, I think that is why it looks moved back. Concerning the alternator and AC Compressor location, they are in the correct location because they are in the same spots on my '88 350 TPI motor which is all original. Hope this helps settle some confusion.
Old Dec 19, 2006 | 04:12 AM
Engine: Your Momma
I'm guessing, but I didn't guess that it was a V6 though.
Old Dec 29, 2006 | 12:06 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
that would be a tuned port v8 painted black with slp runners
that is a 90* serpentine setup and not a 60* setup
the stock v6 intakes are tuned port for the v6 there just not as nice looking
Old Dec 29, 2006 | 11:41 AM
bubba353z's Avatar
Car: 07 Honda CR-V
Engine: Yes, there's one in there...
Transmission: One that shifts itself
I think what is throwing everyone off is that all of the black plastic from the air intake is missing.
Putting on the aftermarket air cleaner certainly opens up the front of the engine - I just don't want to suck in all that hot air under the hood.....
(It's absolutely a V8 - everything else is up for grabs.....)
Old Dec 30, 2006 | 12:23 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
having done a v8 swap in my car, I cain assure you that unless the firewall was moved back, the engine is in stock location. The tranny sits in the same spot, and has just as little room between the block & firewall as the 2.8/3.4/3800.
3.1 got skipped
edit: and goodyear makes teh blue hoses iirc, don't have teh jegs catalog handy to verify.
Old Jan 8, 2007 | 06:00 PM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
That intake might look great but in the end it doesnt do its job. It picks up the heat kicked off the fan and the hot air from the motor if this was placed to the side you would get a better cool air flow from the side that comes up near the fenders.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
