how to get oil fill cap off
Old Jan 10, 2007 | 03:25 PM
SS Ball3r's Avatar
i know this sounds retarded, and yes, i do work on motors myself. Its just i cant get my cap off. it just spins in either direction when im trying to take it off. im 17 and normally i would ask my dad what he thought about it. i just dont want to break it. is it a snap on kinda deal mabye? i dont ahve a manual to refereace either.
Old Jan 10, 2007 | 03:29 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
pull hard. the inside of the cap probably cracked and swelled up. It happens. But you'll need to buy a new one anyway cause you'll either destroy it getting it off or you won't be able to put it back on. It happens.
Old Jan 10, 2007 | 03:53 PM
SS Ball3r's Avatar
is there any way to add oil to my car without breaking that off first. i wanted to drive it tonight, but the oil is a little on the low side and i wanted to add more
Old Jan 10, 2007 | 04:02 PM
Blue1989RS's Avatar
Car: 1989 RS
down the dipstick? You could pull the distributor out too! Lol. I don't know of any way other than those. Good luck!
Old Jan 10, 2007 | 04:26 PM
SS Ball3r's Avatar
yeah, i got the cap off, just neded a little brute force.
now, this is also gonmna sound kinda stupid, but again, im only 17 and even though im pretty good at working on cars and motors, i dont know everything. what happens if i overfill my oil? becasue i did and i dont want to drain all of it annd refill it now
Old Jan 10, 2007 | 05:47 PM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
You have to let some out otherwise you'll blow the motor. slightly overfull is ok. slightly
Old Jan 10, 2007 | 06:13 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Too much oil and it starts hitting the rotating assembly and foaming.... which is never good.
Old Jan 10, 2007 | 10:51 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
stick a pan under the oil drain, and loosen it to the point where oil is coming out, but you can tighten it a tad to stop it.
Old Jan 11, 2007 | 11:25 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
They make a special sucker that you can buy and stick down the dipstick tube. I have one at work and it only cost like $15, but I had to order it online. I'll see if I can find the site again if you want.
Old Jan 11, 2007 | 10:57 PM
Engine: 3.4
Another thing to do, find a 4th gen at junkyard and get the oil filler neck and cap. It's basically an extension that fits pretty snuggly into the valve cover, and the cap comes off easily. I put in on my 2.8 valve cover when I did the swap. It actually bolts to a bracket on the 3.4 valve cover, but I used my 2.8 valve covers. I think it was because they were already installed when I decided to use the neck.
I too hated trying to get my oil filler cap off and on.
Old Jan 11, 2007 | 11:49 PM
Blue1989RS's Avatar
Car: 1989 RS
S10's have the same kind of setup. Kinda nice cause its easy to fill. Did you have to swap the covers too? The S10 covers you would have to.
Old Jan 15, 2007 | 01:45 AM
Engine: 3.4
Nope, the tube fit in just as tight as the cap did (really tight).
Old Jan 19, 2007 | 07:02 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
if that's the first time filling ur car seeing how the cap never came off b4 u might have to wait a few to let the oil go down or else it will look high.
1992 Trans Am
May 10, 2023 07:19 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
