Cold Air Intake
Old Jan 14, 2007 | 07:47 PM
91 v6 Camroz's Avatar
Car: 1991 camaro
Engine: V6 3.1
Cold Air Intake
What is a good cold air intake for 1991 camro 3.1L and about how much horsepower will i get. Thanks
Old Jan 14, 2007 | 08:50 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You can make your own, several here have.
However, most put the 2.8/v8 TPI intake in it that is a dual snorkle. I did a type up on it along time ago how to do it. The intake was also tested by another board member to having very little to no resistance in stock form, let alone slightly modified.
Old Jan 14, 2007 | 09:15 PM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
The intake I have on my 92 3.1L is a custom one by a company called Vibrant. Basically I have a 90 degree angle come out of the intake and into a 45 degree in the exact spot as the stock intake. is a 3 inch tubing. costed me $100. Never got dyno numbers of it but would have to say 10hp. Noticed the engine temperature running 15 degrees colder.
Old Jan 14, 2007 | 11:56 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
please use the search feature. it would of answered every question you have asked. it would have saved you alot of time.
Old Jan 15, 2007 | 07:03 PM
Car: 1991 camaro
Engine: V6 3.1
What should i use plastic piping or metal. and what type of filter?
Old Jan 16, 2007 | 01:56 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
He has a Firebird and you have a camaro. Get the intake from a 2.8 camaro or a TPI camaro and use that. the firebird cant use that intake cause the hood wont clear. you will not benifit on a V6 camaro from anyother intake. The stock CAI pulls air from INFRONT of the radiator and has fewer sharp angles than your gonna get from another intake that pulls air from anywhere else that is a True CAI.
Shouldn't cost you any $100 from a Junkyard, should be able to get one for under $50 (thats what i have seen them for).
Old Jan 16, 2007 | 01:43 PM
Car: 1991 camaro
Engine: V6 3.1
So basically u r saying that the stock air system suplies enof air for the engine right or did i misunder stand u.
Old Jan 16, 2007 | 04:55 PM
xplane's Avatar
Engine: 2.8 MFI
it supplies enough for air 350! your V6 will NEVER need more capacity than what it offers(2.8L is 171ci, 3.1L is 189ci, 3.4L is 207ci).
Old Jan 16, 2007 | 07:11 PM
Dale's Avatar
Engine: 350 S-TPI
YOUR camaro 3.1 stock, does not.
The one for a v8 TPI, or one from a 2.8 v6 does.
Old Jan 16, 2007 | 09:10 PM
Car: 1991 camaro
Engine: V6 3.1
hey thanks but will it still give it more power from the colder air (im not a machanic so i can use all the help i can get)
Old Jan 16, 2007 | 10:21 PM
xplane's Avatar
Engine: 2.8 MFI
A little but most of the benifit comes from the less restriction.
Old Jan 16, 2007 | 10:28 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
the stock 2.8/350 tpi intake setup is about the best you can get on these camaros. if you look at one and see where the air filters are, theyre in front of the radiator, which means, air temp. basically, they come stock with a cold air intake setup stock. and since the 2.8 was equipped with a 350 tpi intake, you know that itll flow more than what is desired for the 2.8 to breathe properly. all you need to do is modify the air box on the bottom side and youre good to go. the home depot special couldnt do better than that, lol. thats basically for firebirds that cant run the camaro intake setup.
btw, IM sent to you.
Old Jan 18, 2007 | 01:24 PM
syko's Avatar
Can someone post pictures of where to modify the airbox (as in where to cut the holes)? I'm broke as hell and I don't want to mess anything up.
Old Jan 18, 2007 | 02:05 PM
Car: 1991 camaro
Engine: V6 3.1
I have look at some cold air intakes and most of them just have a 90 degree angle out of the engine. And some have a 90 degree and then like makes a nother angel and goes toward the ground. i live in tennessee so im kinda afriaid to get one of the ones that go toward the ground because im afraid of water geting in it or can water get in it?
Old Jan 18, 2007 | 02:22 PM
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
When you say ground do you mean near the fender area where the stock setup is?
Old Jan 18, 2007 | 02:46 PM
Car: 1991 camaro
Engine: V6 3.1
no i have seen some the kinda goes between the engine and radiator next to the ground
Old Jan 18, 2007 | 03:11 PM
Dale's Avatar
Engine: 350 S-TPI
thats a second option, that is not part of the factory setup.
Search for a post by me made atleast a year ago (I'm guessing). It shows a how to on install, mod the box, and gut a MAF.
Old Jan 18, 2007 | 08:25 PM
drdave88's Avatar
Engine: 6.0L
heres a pic of my air box now. you can see the ground right in the front of the air box.
Old Jan 18, 2007 | 09:17 PM
Dale's Avatar
Engine: 350 S-TPI
https://www.thirdgen.org/forums/v6/3...ghlight=intake
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
