Good deal or what?
Old Feb 16, 2007 | 05:13 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Good deal or what?
I've been wanting to put new injectors in place of the old stock ones. After looking on Ebay, I saw this (pic). What I want to do is get some aftermarket injectors and put them in this fuel rail and have everything ready to install after I take out the one I currently have in there now. I am also going to replace the FPR while its out. The plenum and everything else is something to have on hand. The total cost with shipping and handling was $85. Good deal?
Ken
Old Feb 16, 2007 | 05:19 PM
pairtoe's Avatar
pretty good deal, i am acutally doing the exact same thing right now.
is the stock fuel injector flow rate 15/lbs per hour?
Old Feb 16, 2007 | 06:05 PM
ken3983's Avatar
If I'm not mistaken, the stock injectors are 15 lbs/hr.
Ken
Old Feb 16, 2007 | 07:16 PM
pairtoe's Avatar
yeah thats what i thought to. what kind of injectors are you planning on getting?
these are what i want:
http://store.summitracing.com/partde...150619&FROM=MG
Old Feb 16, 2007 | 08:22 PM
firstfirebird's Avatar
Ken
Why wouldn't you just use your fuel rail and put in new injectors to save yourself the money for upgrades?
Old Feb 17, 2007 | 08:20 AM
ken3983's Avatar
True, I could use the money towards upgrades, but I'd rather have an extra fuel rail to have already made up to save some time even though it's not that much time saved. At least, I get the upper and lower intake manifold in the auction. I want to put Accels in, but I heard some people had trouble with some of them. The guy at cruizinperformance said look for the black and silver Accels rather than the black and yellow ones. Anyone ever seen black and silver ones?
Ken
Old Feb 18, 2007 | 01:57 PM
pairtoe's Avatar
yeah summit has the black and silver ones.
Old Feb 18, 2007 | 02:05 PM
Personally, I like the Bosch or Denso injectors. I've got a set in my pickup (orange) with almost 180000 miles on them and no problems.
Old Feb 18, 2007 | 04:43 PM
ken3983's Avatar
Anyone know what the Summit Racing part number is for the Black/Silver Accels?
Ken
Old Feb 20, 2007 | 07:52 AM
pairtoe's Avatar
these are the ones im getting they are black and silver and 19lbs
Old Feb 20, 2007 | 04:43 PM
You might need an adjustable fuel pressure regulator (AFPR) or you are going to be running rich.
Old Feb 21, 2007 | 08:05 AM
pairtoe's Avatar
ive been looking for one that will work with the stock fuel rail but i cant find one any where, becasue i am planing on running a turbo and i am updating my fuel system.
Old Feb 21, 2007 | 01:34 PM
I took the spring out of mine and put a AFPR in the return line.
Old Feb 21, 2007 | 07:34 PM
pairtoe's Avatar
how hard was that to do?
Old Feb 22, 2007 | 12:11 AM
Gotta get the fuel rail out and the FPR is held in by some tamper-resistant torx screws. Remove them and cut the spring, reassemble. The AFPR was a matter of cutting the rubber return line and putting in the AFPR, along with connecting the vacuum line in the stock location.
EDIT : This is not recommended advice, you should tune properly in the ECM. You can actually put a turbo on using stock injectors and low boost.
hectre13
Dec 11, 2023 08:14 AM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
ChevyZ71
Aug 13, 2015 07:30 AM
