2.8l vac leak
Old Mar 6, 2007 | 01:37 PM
SouLTeRRoR's Avatar
2.8l vac leak
Ok I know the pic isn't very good but my car is buried under snow right now. So anyway I have a leak right here.
There are 3 holes, and only 2 lines. Now I want to know is there suppose to be a 3rd line and if so where does it go? If not what's the best way to plug it? I have a screw right now, but it's not fully screwed in.
Old Mar 6, 2007 | 02:06 PM
tech1's Avatar
on mine their is the same vac plug only two lines connect to it . what i did was went to my local junk yard and found the same vac plug with no craks in it . also check and make sure you dont have a leaking throtlebody
Old Mar 6, 2007 | 02:11 PM
SouLTeRRoR's Avatar
I'm a noob when it comes to cars. So how would I go about checking for a leak in the throtlebody?
Old Mar 6, 2007 | 03:29 PM
pairtoe's Avatar
the third holes is bigger, and there should be a rubber plug in the end of it.
Old Mar 6, 2007 | 07:00 PM
SouLTeRRoR's Avatar
Ok so I just have to get a plug then. Thanx for the help just have to find 1 now.
Old Mar 7, 2007 | 06:49 AM
tech1's Avatar
get you a can of throttle body cleaner and spray around vac lind and throttlebody and if idle levels out or increases their is a vac leak in that area
Old Mar 7, 2007 | 07:50 AM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Hey Mark! :P
Old Mar 7, 2007 | 03:49 PM
SouLTeRRoR's Avatar
Sup Noah and thanks for the help guys.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
aaron7
Sep 30, 2015 09:15 AM
