cam is stuck in and wont pull out, what am i doing wrong
Old Mar 8, 2007 | 07:56 PM
luckyou03's Avatar
ok i got a rebuild 3.1l long block sitting in my garage and im trying to remove the stock cam but it wont come out. It spins freely and will slide out about a quarter of an inch. I have 3 bolts on the cam that im using as a handle and i just about put my full weight on pulling this out and it wont budge. Theres no distributor in or timing gears. its just the bare short block. Is there some snap ring im missing somewhere or something
Old Mar 8, 2007 | 08:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Did you take the lifters out?
Old Mar 8, 2007 | 08:02 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Did you remove the lifters?
Old Mar 8, 2007 | 08:05 PM
luckyou03's Avatar
all of the lifters are out.
Old Mar 8, 2007 | 08:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Tried turning the crank?
Old Mar 8, 2007 | 08:36 PM
luckyou03's Avatar
ok i yanked on it some more. slid it back and forth and it still wouldn't budge. So i removed the back plate and it wouldn't slide out that way either. At this point im getting annoyed by this. So i sliding it back and forth as hard as i can and its still stuck. So i broke out the mallet and used a rod and hit the back of the cam about 3 times and it finally slid forward out of the bearing. when it slid off the bearings it scared them up pretty good so thankfully this engine it out of the car. I'm guessing that the clearances where really tight maybe one of the bearings where installed wrong or something. I can get new bearings for around $20 or $30 so no big deal.
Old Mar 8, 2007 | 10:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If the clearances were that tight the cam wouldn't have turned.
Old Mar 9, 2007 | 11:08 AM
pletch's Avatar
Car: 86Camaro RS
Engine: 2.8L V6
HIT IT
I like your method, hit it till it breaks, and if it breaks it needed replacing anyways
Cameeeero
Sep 18, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
anesthes
Aug 8, 2015 09:37 PM
