2.8 - 3.1 or 3.4
Old Mar 22, 2007 | 12:48 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
2.8 - 3.1 or 3.4
I wanna swap out my 2.8
Can I just unplug and pull out and bolt in a 3.1 or 3.4 using the same wiring harness. What is involved in this swap
Old Mar 22, 2007 | 02:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well covered on the V6 forum, where this will now reside.
Old Mar 22, 2007 | 04:11 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: 2.8 - 3.1 or 3.4
yeah, if you drop in a 3.1 from another 3rd gen F-body it should work fine. The 3.4 is complicated subject, but there exist 3.4 motors where the ONLY difference between them and the 2.8 is the bore and stroke. you just gotta find one or build one.
Old Mar 22, 2007 | 04:23 PM
daves12secV6's Avatar
u can take a 3.4 out of a 4thgen, u need to swap the front timming cover/accesorys over,and replace the 3.4 upper manifold with the one off a 2.8 or 3.1,but u reuse the 3.4 injectors.other then that its all minor stuff to swap over
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
usafirebird
Sep 29, 2015 11:58 PM
92projectcamaro
Sep 29, 2015 07:07 PM
spartanreaper
Sep 25, 2015 07:22 PM
