A/C Eliminator Pulley For The 3.1 Available?
Old Apr 28, 2007 | 10:21 AM
locomoshun's Avatar
I've searched high and low, does anyone know where I can get an air condioner delete pulley setup for a 91 Camaro 3.1? I've found stuff for the 3.4s, but that's no help to me. Thanks
Old Apr 28, 2007 | 10:25 AM
pairtoe's Avatar
Re: A/C Eliminator Pulley For The 3.1 Available?
i belive ive seen them on summit before.
Old Apr 28, 2007 | 10:50 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
SUMMIT has them.
Old Apr 28, 2007 | 04:28 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Can't you just get a shorter belt instead of getting a !AC pulley? I know on my 2.8 it gives a pic of the belt route with or without AC.
Old Apr 28, 2007 | 08:19 PM
locomoshun's Avatar
Maybe I missed it, but all I saw at the Summit website was a setup for the 2.8 and the 3.4. If anyone know the correct Summit part # please post it.
Old Apr 29, 2007 | 08:11 PM
firstfirebird's Avatar
Got to the auto parts store and ask for a belt. When they ask you if you have A/C, tell them no and route your belt according to the diagram above the radiator. This will cost less time and money then getting the delete pulley. Is there a reason you want to keep the long belt unnecessarily?
Old Apr 29, 2007 | 09:33 PM
locomoshun's Avatar
I've deleted the power steering pump, air pump, and compressor. I need something on the left side of the engine to make all this work.
Old Apr 29, 2007 | 09:49 PM
Still, take a piece of rope and run it around the pulleys in the direction you need and mark/measure it, actually I just got what you are saying, lol.
You now only have the crank, water pump, alternator and idler?
Old Apr 29, 2007 | 09:59 PM
91_rs-teal's Avatar
Car: 1991 Camaro, Best 12.40 @ 115.8 MPH
Engine: LS1, HCI, Headers
Transmission: T56, Monster Stg. 4
Axle/Gears: 7.5" 10 Bolt - 3.73's w/ posi
for a/c and smog delete i am running a 81.7in. belt
Old Apr 29, 2007 | 10:11 PM
The PS pump was also deleted.
Old Apr 30, 2007 | 07:11 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I bought one for my new v8 off ebay for 40. It says it is to fit v6's as well as the pumps are extreamly similar.
Been on 2 weeks and working fine.
Old Apr 30, 2007 | 07:31 AM
locomoshun's Avatar
Dale: What brand did you buy, and for what year?
And yes, I now have crank pulley, water pump, alternator, and idler. I want the a/c pulley as I don't think the bend around the water pump is enough for a good grab.
Old Apr 30, 2007 | 12:22 PM
Dale's Avatar
Engine: 350 S-TPI
since we cant post link to auctions I will give you his user name "parts-2-you".
Both of my cars are 1991's.
Old Apr 30, 2007 | 01:50 PM
locomoshun's Avatar
Thanks Dale, I'll give it a shot.
Old May 1, 2007 | 09:14 AM
locomoshun's Avatar
Dale, I did find the seller and sure enough it does list the 91 V6. The three bolt pattern looks the same. I ordered one up. Thanks.
Old May 1, 2007 | 10:05 AM
Dale's Avatar
Engine: 350 S-TPI
not a problem, thats what were here for.
Old May 4, 2007 | 07:03 PM
locomoshun's Avatar
I got it in today, it works like I wanted. Awesome.
Old May 4, 2007 | 08:15 PM
Pics?
Old May 4, 2007 | 09:19 PM
locomoshun's Avatar
I just got in, and I tore everything off the engine in prep for painting. When I get it all done I'll post a pic.
Old May 4, 2007 | 09:34 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I used a seamstress' measuring tape to determine the length of my new belt after I got rid of my smog pump. BTW, my car has no A/C from the factory and has no delete pulley.
Old May 5, 2007 | 08:03 AM
Good idea with the tape!!!
If you read the earlier posts, locomoshun gave up the power steering as well .
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
