Car shuts off on rolling stop...
Old May 14, 2007 | 10:47 PM
Sickcuban's Avatar
Car: 1984 Camaro
Engine: LG4 305 - Conversion Commencing
Transmission: TH700-R4
Axle/Gears: 4.10
My girlfriend has a 92 RS 3.1L and when she comes to a stop sign the car just shuts off sometimes...not all the time. It started a while back and just went away and now its back...When the RS comes to a stop (when I drive it) the rpms bog around 600-800 i wanna say...so it bounces. Do you guys have any ideas what it could be...TPS maybe IDK anything about these cars. Could it be an injector because today the injectors, when i popped the hood, one on cyl 4 I believe was really loud ticking....it was only comin from the passenger side of the car and it sounded really loud, but its kinda always been like that and Im gonna get em cleaned...could that be the problem? any help is appriciated.
Old May 15, 2007 | 12:08 AM
z28camaroracer's Avatar
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
Re: Car shuts off on rolling stop...
Pull the idle air control motor and clean it with carb cleaner or replace it. It is not keeping the idle high enough to keep it running. This could also be a sign of a transmission problem if the torque convertor is staying locked up when stopping.
Old May 15, 2007 | 10:01 PM
Sickcuban's Avatar
Car: 1984 Camaro
Axle/Gears: 4.10
Well today we pulled the car apart...the entire distributer is fried...so yea I believe that is the problem, cause i was drivin it and was like...wtf is goin on with the RPM gauge...so we took it out since the car needs the intake manifold gaskets cause of an oil leak...and the coil was pretty bad, like all flaking and torn up...but we are gonna clean everything. Thanks anyways man.
Old May 15, 2007 | 10:26 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
that reminds me, i gotta fix my RPM gauge.....it stays in the redline.
Old May 16, 2007 | 05:38 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Have you changed your fuel filter?
theshackle
Sep 17, 2020 08:26 AM
kah992
Aug 19, 2015 02:55 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
