Pulling A 3.1 v6
Old May 30, 2007 | 08:07 AM
Little John's Avatar
Pulling A 3.1 v6
I'm going to replace my sons bad motor with a new 3.1, can I pull the motor with out the trans. the service manual says you have to drill holes in the fire wall to get the upper trans bolts? Please give me some insite any an all would be helpfull. My boy has been bumming for three week with out his 92 bird. Thanks Little John
Old May 30, 2007 | 02:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moving from Engine Swap to V6 forum.
(I can't imagine the answer being you have to pull tranny with engine, since you can get to the bellhousing bolts with a V8.)
Old May 30, 2007 | 02:39 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Pulling A 3.1 v6
I recently pulled out the manual tranny on one of my '92 birds. With the A/C, and/or Heater box removed (makes a world of difference if you don't have a lift), the bolts are easily accessible. So to answer the question, no, you do not have to drill holes into the firewall....
BTW, I would honestly consider a 3.4 for your son in it's place.
Old May 30, 2007 | 03:35 PM
daves12secV6's Avatar
if u remove the tq arm and the trans crossmember and let the transmission hang down u can get to the top 2 trans bolts with a long extension and a swivel/swivel socket
Old May 30, 2007 | 04:26 PM
firstfirebird's Avatar
I'm getting ready to take mine out also this will be my first engine pull on a thirdgen.
Last tranmission I put in a thirdgen (85 Camaro 305), I certainly didn't drill any holes in the firewall. Didn't even read the manual because tranny swaps were common (my frind and I had a small shop). The ones I've done in the driveway were a pain, but when I had access to a shop the lift and tranny jack made it a lot easier.
Make sure you take your time and an extra person or two is always nice.
Old May 30, 2007 | 09:06 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yes you can, I pulled mine w/o the trans attached.
Old May 31, 2007 | 08:47 AM
Hi,Thanks for the reply, any quick tips you may have would be helpfull.I know the 3.1 an trans sit tighter to the firewall than the v8. Thanks Little John
Old May 31, 2007 | 10:09 AM
Dale's Avatar
Engine: 350 S-TPI
there are ground wires bolted to the back of the heads that are PITA to get loose while motor is in(or was that the s10?).
I would suggest pre-removing the dizzy if you plan on using it in the next motor.
Can be pulled out with radiator in the car, but I highly suggest removing it.
Really, other then double checking your wires, its a strait up basic pull. Putting the one back in was a little pita while trying to attach a 700r4 at the same time. The motor brackets didnt want to drop on the mounts for me.
Old May 31, 2007 | 10:37 AM
Hi Dale, Thanks for the input I was planing to pull the rad an the dizzy should I pull or do I have to pull the injection intake to clear the right rear lifting bracket? I see it looks like a normal pull an its not my first but from past motor pulls each car model has its querks. thanks Little John
Old May 31, 2007 | 11:29 AM
Dale's Avatar
Engine: 350 S-TPI
The chains or cable will hit the upper intake, yes. If you plan on reusing, or selling, Id pull it as well. If your just dumping for a core charge, dont waist the time.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
