Did I gut the airbox enough?
Old May 15, 2007 | 07:04 AM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
is that good enough or should i cut more?
Im thinkin about doing that ram air where u take some metal and make a airway from the grill to the filters.
Old May 15, 2007 | 07:15 AM
vortecRS's Avatar
Car: 87 RS with a 4.3 votec
Engine: a cammed 1996 4.3 vortec
Transmission: currently TH700R4
Axle/Gears: stock with 3.43s
Re: Did I gut the airbox enough?
lol iv hurd of drilling hoes in the bottom but iv never hurd of cutting it off lol i guess it would work tho
Old May 15, 2007 | 07:27 AM
86camarokid's Avatar
Car: 86 Camaro
Engine: 2.8L mpfi V-6
mine was like that when i bought it so i'd say thats more than good..plus for added "ram air" you could put like a scoop on the back of it, lol make it look like a feed scoupe, some one else on the board did it and it looked really nice, now if it helped who knows
Old May 15, 2007 | 08:37 AM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
It's what I've read a bunch of times on this forum. Leaving about 1-1.5" left.
Old May 15, 2007 | 08:53 AM
vortecRS's Avatar
on like the pice thats attached to the car in the nose?
Old May 15, 2007 | 08:56 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
It's a pointless mod. The stock air box flows enough air for a stock 350, a motor 2 times the size of the 2.8. But that is what it should look like if you ever start to outflow a 5.7L
Old May 15, 2007 | 07:52 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
That's more than enough. I put scoops on mine when I did that a few months back. If you add scoops you will get alot more stuff in your filters.
Old May 31, 2007 | 07:49 AM
1990Wolfman's Avatar
Car: '90 Chvy T-tp Rs wth Z28 frntclip
Engine: 3.1 atm
Transmission: Crap atm
Axle/Gears: see tranny
hope it does not rain where you guys are, your just asking for water in your air intake... thats why the stock airbox was made the way it is... the scoop will only increase the amount of water, debris you ingest.
Old May 31, 2007 | 08:50 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I have had the scoops on mine for 6 months and haven't had any problems with water or the filters getting clogged. I just cleaned them and there were a couple of bugs that got stuck but nothing major threatening the motor or filters.
Old May 31, 2007 | 09:32 AM
Engine: 3.1 atm
well I guess you dont have a direct flow then, you got lucky. Most other cars had trouble with sucking water, o well
Old May 31, 2007 | 12:06 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I think that my grill has something to do with it. It's a stock RS grill, it's pretty good at blocking off bugs and such.
Old May 31, 2007 | 03:57 PM
firstfirebird's Avatar
If you have a quality filter, it should be fine. I have friends with snorkels on their truck sticking 6" above the roof and open to the elements. It rains a lot here in FL and they don't seem to have problems using a K&N cone (and no sock).
Old May 31, 2007 | 04:16 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
That is one reason why I switched to K&N. I figured that they would hold up better and keep more water out than the paper filters. So far it has been a drought here. It is very dry. Where are the hurricanes?
Old May 31, 2007 | 06:03 PM
Don't say that word! (hurricane)
I'm still repairing damage to my house after Wilma (the one nobody talks about) .
Linson
Oct 24, 2025 02:00 PM
Jeremys87
Jul 14, 2022 09:08 PM
TRAXION
Aftermarket Product Review
Oct 24, 2000 05:23 PM
