turn key but nothing sometimes
Old Sep 5, 2007 | 03:08 PM
xiholdtruex's Avatar
Car: 88 prelude si/91 camaro rs
Engine: 2.0/3.1
Transmission: D2J5/700r4
i have a 91 rs 3.1L with new starter,alternator,distributor,ignition coil,battery,cables,plugs.sometimes i turn the key to start but it does nothing and i have to turn it a couple of times before it decides to start.what do you guys think this might be?????all help is appreciated
Old Sep 5, 2007 | 04:11 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: turn key but nothing sometimes
VATS....
Old Sep 5, 2007 | 04:15 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Originally Posted by Street Lethal
VATS....
I agree. That could be it. Or, maybe even the solenoid on the starter. I know it's a new starter but strange things like that have happened to me before in the past. Just a suggestion
Old Sep 6, 2007 | 12:50 AM
Engine: 2.0/3.1
thats what i thought also.how can i check if its that???how would i bypass that if possible???or repair it????
Old Sep 6, 2007 | 06:16 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Check the resistor on your key. If its worn down you might just need a new key that matches yours.
Old Sep 6, 2007 | 07:28 PM
H8TRAFIC's Avatar
Check the starter before the VATS. Mine would do the same thing and would always eventually start after 2 or 3 tries- until it left me stranded! That is when I found out it was the starter. The 'no start' was a warning according to my mechanic.
Old Sep 7, 2007 | 08:50 AM
ncarrier's Avatar
Car: 1989 Camaro
Engine: 2.8 V6
you could just do what i did and run two wires from the starter to a push button switch. you still need the key to activate the computer for it to run but other than that just press a button and you up and running. my vats went out. just a thought
Old Sep 7, 2007 | 03:42 PM
Engine: 2.0/3.1
How would i go about doing this???
9192camaro
16
Feb 3, 2019 12:21 AM
GTAman
Sep 21, 2015 09:57 AM
5spdcamaro
Aug 28, 2015 02:12 AM
Bryan F
Aug 18, 2015 02:28 PM
wayshegoes
Aug 17, 2015 12:00 PM
