Cam or headers?
Old Sep 25, 2007 | 02:10 PM
92Birdofprey's Avatar
Car: 92 Firebird
Engine: 3.1
Axle/Gears: stock, dynomax turbo exhaust
Cam or headers?
Hey guys I'm looking for headers and a cam (less expensive as possible), I just put in a dynomax exhaust system and I'm really happy with the results, I didn't buy a catalytic converter, should I get one, does it make a difference? What do you think is worth getting more, A cam or headers? and if I change either one, would I have to make any changes to the computer?
California Car
Old Sep 25, 2007 | 03:20 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: Cam or headers?
There are no smog legal headers for the 3.1L. So I would look into cams.
Old Sep 25, 2007 | 03:51 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: Cam or headers?
Cams, more bang for ur buck.!
Old Sep 26, 2007 | 06:15 AM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Re: Cam or headers?
I have the smog illegal headers with a high flow cat and my car passed the NJ state inspection in July. But I would do the cam if you could only choose one but why not just get both.
Old Sep 26, 2007 | 05:06 PM
xiholdtruex's Avatar
Car: 88 prelude si/91 camaro rs
Engine: 2.0/3.1
Transmission: D2J5/700r4
Re: Cam or headers?
by the smog illegal headers do you mean the 2.8 pacesetters? lol just wondering.....
Old Sep 26, 2007 | 07:29 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Cam or headers?
I would do headers then cam. You will get more out of the cam with headers. Not to mention that they will make your car sound better.
Old Sep 27, 2007 | 11:37 AM
Car: 92 Firebird
Engine: 3.1
Re: Cam or headers?
I want to get a cam and headers but these California laws are serious so I rather not for now since I probably would have to pay some serious money to make it pass or worse yet I won't be able to get my stickers. Would it help if I get the 2.8 headers and California Illegal Cam and a High flow Catalytic converter, would I have a chance of passing? It seems like I can't do anything to this car, or should I just wait and save up for a turbo or buy an MSD ignition system, how good are those MSD's by the way?
Old Sep 27, 2007 | 08:03 PM
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Re: Cam or headers?
yes i am talking about the 2.8L headers by pacesetter. The 3.1L does not have its own headers.
Old Sep 27, 2007 | 10:30 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: Cam or headers?
The 2.8 headers will fit but you have to get rid of the smog pump. For a cam you can probaby run one a little larger than stock and be fine.
Old Sep 28, 2007 | 02:32 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Cam or headers?
The 3.1 and 2.8 have the same heads so it'll bolt up fine. Pacesetter says they're 50 state legal so it should pass as long as the emissions crap is hooked up. You won't need to reprogram the computer just swapping the headers, but you might with a cam change.
I'd go with the headers first because they'll actually raise torq. A cam can raise power but with these engines (especially iorn headed) it has to be done in conjunction with other mods to give any noticeable gain. Most cams out there for these engines just move the powerband around to make it 'feel' like a performance gain- the notable exception being crane's solid profiles. Your money would be better spent having the heads ported or better yet completely replaced with aluminum ones.
Old Sep 28, 2007 | 02:57 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: Cam or headers?
Sure they are great but it creates a world of other problems that have to be addressed.
Old Sep 28, 2007 | 03:07 PM
bl85c's Avatar
Car: '85 maro
Re: Cam or headers?
Yep, alot of parts need to be swapped out but they're 1000X better than the iorn heads. The 3400 top end swap is well documented so it can be done by just about anyone.
Old Oct 7, 2007 | 02:43 AM
sewerrat's Avatar
Re: Cam or headers?
Hello, I'm a newB here. What's a 3400 top end kit? Is that a FWD engine?
Old Oct 7, 2007 | 11:20 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: Cam or headers?
It is the FWD engines. They are aluminum heads that flow much better than the iron heads. To do the swap you also need the pistons, intak, TB, and a few other parts. Its pretty involved swap but is is worth it. You'd also have to fab up something for ignition.
Old Oct 7, 2007 | 11:43 AM
bl85c's Avatar
Car: '85 maro
Re: Cam or headers?
Or cut a chunk out of the intake. Most people switch to DIS anyway.
Old Oct 8, 2007 | 09:47 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Cam or headers?
Headers because they will increase you power at just about every rpm and throttle position. My 3.1 has headers, ported 1986 2.8 fiero heads, and nice little cam. Really my only affordable choice of headers for a 4x4 S-series Blazer was Edelbrock. They are made well and really picked up the power of the old 2.8. Additional gain was realized when the modified 3.1 was put in place of the stockish 2.8. I should mention it is a TBI engine that we also bored out the intake manifold and are running a 305 TBI unit on (was done when it was still a 2.8). V6 guys running a MAP based system will need chip work to make the engine run correctly. My truck was undriveable at first after the mods.
This is what a good smog legal header kit will look like for a 2.8/3.1/3.4
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 8, 2007 | 11:22 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: Cam or headers?
Those are for a S10/Blazer. The only company that makes headers now are Pacesetter. Edelbrock makes good headers and I would love a pair but they probably won't fit around the engine bay.
Old Oct 8, 2007 | 04:59 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Cam or headers?
I know they are for a S10, but I was simply stating that is what a good set of smog legal headers look like.
This is what my 3.1 sounded like before I put an exhaust system on the Y-pipe of the Edelbrock TES system. This is prior to me tuning it. It was running on a 4.3 TBI prom in this video. Hence why it died when I suddenly pushed hard on the gas.
http://youtube.com/watch?v=gdQENVYISPs
http://youtube.com/watch?v=yK2agWA1zhw
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
