Anyone here have a cammed 2.8?
Old Sep 30, 2007 | 08:39 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
And would you mind posting an exhaust sound clip for me? When I get around to replacing the intake manifold gaskets, I'm thinking of installing a cam just for fun... Thanks!
Old Sep 30, 2007 | 08:43 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Anyone here have a cammed 2.8?
There is a vid floating around here that has a 2.8 cammed in it. I'll have a cammed 3.1 here in a few months.
Old Sep 30, 2007 | 08:59 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
http://www.fquick.com/videos/Idle/635
Old Sep 30, 2007 | 09:55 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have a cammed 3.1 with TBI.
http://youtube.com/watch?v=gNVs-_RzwFo
Old Sep 30, 2007 | 10:06 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
wuts a good cam to go with a 2.8 ????
Old Oct 2, 2007 | 04:03 PM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Originally Posted by cooltc2004
Is this your exact car cause if so we have the same color and rims
Old Oct 4, 2007 | 01:21 AM
Duracell Bunny's Avatar
Nope, But have roller rockers on a stock cam and she scoots pretty good for a little 2.8. There isn't anything else stock about this car at all except the bottom end of the motor.
Here's an in cockpit video clip of it braking and accelerating. The car is an '87 2.8l auto with 3.23 gears. It runs high 15's which is slow, but very very repectful for a 2.8V6 on all motor only.
http://www.zippyvideos.com/681124941...ilwaffarn_010/
Old Oct 4, 2007 | 06:48 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
That car does move pretty good. I wonder how mine will do with a cam.
Old Oct 4, 2007 | 08:48 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
I'm ordering my cam next week and completing my rebuild in a couple weeks from now. I'm using the towing cam from the S10 Blazer's 2.8 to increase the low-end. I'll let you know how it goes when I'm done, if you're interested.
Old Oct 4, 2007 | 10:58 AM
It'll take a whole lot more than just a cam. I have over 30k into this car modification wise. The drivetrain is extremely lightweight and exotic. APCT CF driveshaft for one, moser drilled axles, Trans is wickedly built.... it goes on and on. Just one fun daily runner for around town use.
Old Oct 4, 2007 | 12:02 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Depends on your intended use of the car.
A cam for daily driver is not the same one you would want for drag, or autox, boosted, etc.
Old Oct 4, 2007 | 03:23 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
The way you described your car it sounded like it was just completely stock except for the cam. I got a 260H, ported heads, 1.6 roller rockers to go on a 3.1 that I am going to be getting soon. Mine has a little suspension work but from the sound of your car I have won't scoot that good. I'm just doing this to be reliable, nothing crazily modded.
Old Oct 5, 2007 | 03:12 AM
Nope, But have roller rockers on a stock cam and she scoots pretty good for a little 2.8. There isn't anything else stock about this car at all except the bottom end of motor
This sounded like I said I had just a cam with everything else stock?
Old Oct 5, 2007 | 10:13 AM
92Birdofprey's Avatar
Car: 92 Firebird
Engine: 3.1
Axle/Gears: stock, dynomax turbo exhaust
How bad is a high performance CAM on emissions? I have a fuel injection firebird 3.1 and I want a high performance cam, can I get away with it in California?
Old Oct 5, 2007 | 10:27 AM
Safely you can run .440/,440 lift on a fuel injection car (MPFI) and still pass without too much dirty overlap, Nor messing to badly with the computer sensors.
Old Oct 5, 2007 | 03:58 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I don't know how I got that out of what you posted. I guess that I was just really tired that day lol. I am out of it after school and a hard's days work some days.
Old Oct 6, 2007 | 01:05 AM
Here is the car if interested in veiwing.
http://www.cardomain.com/ride/518752/1
Its a radical daily driver I built for my wife. Took something different and built it into my version of a grocery getter. Its my family car per say. This car corners like you can not believe. It really does not need massive power to enjoy since it carriers its speed. Its just fun to drive daily and is not ment to be a massive HP garage queen.
Old Oct 6, 2007 | 11:10 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Here is my little cammed V6
http://media.putfile.com/Cammed-3500-V6
.549 lift/293 advertised roller cam
315 HP/296 TQ
Old Oct 6, 2007 | 12:25 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
You could always dump some G2P in the tank. Does just what the name implies, you're Guaranteed to Pass. Took my emissions without a frequency card in the maf and I passed!
Old Oct 6, 2007 | 12:41 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Yes sir it is. You have an FQuick ?
Old Oct 6, 2007 | 01:39 PM
Engine: 450HP 355
Transmission: TH350
with a larger cam, any idle test will be hard to pass, if you have the ability to tune the car you can reduce the VE tables at idle, then bump up the spark timing a little to get rid of the rich idle.
As long as you have a good cat it should be ok if you don't go too agressive with the cam.
Old Oct 15, 2007 | 07:51 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
here is a clip of my car with open headers while waiting in line at the strip
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Zane Story
Oct 8, 2015 12:40 PM
Jorlain
Oct 8, 2015 01:57 AM
snakeshooter
Sep 7, 2015 11:13 AM
rjcme
Sep 5, 2015 01:23 PM
