Sub Zero Temp. Outside What Should I Worry About? (V6)
Old Jan 23, 2008 | 05:24 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Unusual cold spell in good old Wyoming, range from -30 to 2 º F above, the past week. What should I worry about besides the basics? I did learn that V6 dont like cold (-10 º F). Hard start.
Old Jan 23, 2008 | 06:16 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Sub Zero Temp. Outside What Should I Worry About? (V6)
Appropriate antifreeze. I believe 50/50 is good up to -80F? Someone correct me if I'm wrong there. A battery with a higher CCA rating will start easier in cold. That's about it.
Old Jan 23, 2008 | 06:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not even close, more like -35F or so. 60/40 is good to -60F, which is colder than anything in the lower 48 is ever going to get. To get to -80F you'd need 70/30.
Old Jan 23, 2008 | 08:20 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
If your TB is bypassed then it could get stuck open in really cold weather.
Old Jan 23, 2008 | 09:03 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
30 weight oil .... anti-freeze like others said .... as far as him relying on a thermometer or weather forecasters wouldn't he have to factor in wind chill as to his ultimate coolant mixture? Get a block heater that will end all of your troubles and allow the coolant to be warm before you ever start it.
on a side note though .... that is some serious cold air induction LOL
Old Jan 23, 2008 | 09:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
30 weight oil would actually be a bad idea. 5w30 would be better, or if it was really cold, then 0w30.
No need to worry about wind chill, cars don't have skin.
Old Jan 23, 2008 | 10:46 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Cracking interior parts.
That's what I got from the weather here in Denver.
Old Jan 23, 2008 | 11:12 PM
Engine: 4.0 V-6
I meant 5w30 actually ... sorry I just call it 30weight is all
Old Jan 24, 2008 | 12:48 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
30 weight and 5w30 are completely different animals.
5w30 or 0w30 would be the oil to use.
Probably the most important thing would be to plug in the block heater. Put it on a timer so it runs for 2 hours before you start the car in the morning (assuming 0°F) and all night if it's -30°. Makes a world of difference. Warms the block, the oil, and the coolant. Easier starting, better fuel economy, less pollution, much less wear on parts.
Might want to invest in a battery heater. A little blanket type thing that plugs in.
Hope you're not running a 160° thermostat. You're losing inside cabin heat and fuel economy, not to mention wear.
Good point above about the not doing the TB bypass. In this case, you'd want that warmed up air going into the TB. Probably more of a factor on the highway than for slow city driving.
50/50 antifreeze is good to -37°C which works out to -35°F. Should be OK with that.
If you're just dealing with cold and not with snow and iced up windows, start driving after a minute. No need to let it warm up longer than that. Cars warm up faster when they're driven than they do when they're idling in one spot. The faster the warmup, the better for the engine. Just take it easy until everything is up to normal temperature.
I like the "Plug at 20°" plan.
http://www.ci.anchorage.ak.us/healthesd/WhyPlug20F.cfm
Last edited by Reid Fleming; Jan 24, 2008 at 12:51 AM. Reason: Automerged Doublepost
Old Jan 24, 2008 | 06:50 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
That happened to me a couple of weeks ago down here in FL in about the same spot. Really that is the worst thing that could happen.
Old Jan 24, 2008 | 10:08 AM
KBcobra's Avatar
Engine: 3.1L V6
lol windchill thats a different story, my car sits in the garage at around 33 degrees, i have 10w-30 im probably goin to change it to 5w, but when I go to school what worries me sitting 7-12 hours in the cold. Anti Freeze iirc is good for -35 or so below, when i did that thermostat change last winter and replace the anti freeze i didn't expect it reach -35 this winter. Thanks for info very helpful
Old Jan 24, 2008 | 10:16 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
don't 4get to change your windshield washer fluid to a better combination. I've read the bottles and it only says like a 5* difference, but i've never had the pink stuff freeze as apposed to the blue stuff. Don't need to crack the container even if it is relatively cheap to replace or burn out the motor. Other than that it's all about covered. Also for winter months i suggest removing the dash pad if it is in good shape. That's what i do and haven't had a problem yet. Good luck!
Old Jan 24, 2008 | 10:26 AM
KBcobra's Avatar
Engine: 3.1L V6
Usually never this cold. Global warming my ***
Old Jan 24, 2008 | 10:29 AM
84redta's Avatar
lol, didn't you get the memo...it's all just a rumor, lol.
Old Jan 24, 2008 | 03:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's why it's properly called "climate change", not "global warming".
I don't know though, I'm from Edmonton. If you guys are complaining this much at -35, I'd hate to hear the noise you'd make if it actually got cold.
Old Jan 27, 2008 | 08:25 PM
cool z's Avatar
Car: 91 Camaro vert
lol yeah its been getting cold in ND got to -40 the other day...dam dash cracked...not to big thow...and you probly want to get block heater if its your daily driver, but its probly dosent stay -40 degrees for days on end
Ice + rwd = no movement
Old Jan 27, 2008 | 08:56 PM
KBcobra's Avatar
Engine: 3.1L V6
Ice + rwd = fun
RedLeader289
May 28, 2019 01:47 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmorgetRS
Sep 28, 2015 09:33 PM
ramicio
Sep 28, 2015 01:18 PM
