Injecter wireing info
Old Mar 30, 2008 | 04:45 PM
83camaro86's Avatar
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
What happens if the injecters are not wired back up right. The reason i ask is i am not sure if i have them hucked back up right. Thanks for your help
Old Mar 30, 2008 | 07:48 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Injecter wireing info
Injectors will fire at the wrong time so then the motor would't fire.
Old Mar 30, 2008 | 07:59 PM
83camaro86's Avatar
Axle/Gears: stock
So the motor would not idle or nothing right. Just trying to find the reason y it want take gas when pressing the peadal. Thanks
Old Mar 30, 2008 | 08:38 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Well, this is batch fire. It really wouldnt matter all that much if they were switched around to be perfectly honest.
As long as they are all firing, it will run.
Old Mar 31, 2008 | 08:28 PM
83camaro86's Avatar
Axle/Gears: stock
would it effect the dive ablyt of it. Could you still rev up the motor and every thing be fine. Or running right. Thnsk for the help
Old Mar 31, 2008 | 08:40 PM
Toehead's Avatar
Over a certain RPM it wouldnt be noticeable.
The big thing would be a little idle instablility.
Old Apr 1, 2008 | 06:19 PM
83camaro86's Avatar
Axle/Gears: stock
Well ok. My problem is that it idles fine. But when you try to give it some gas it starts to die. If you hold it right there it will start to run fine but also start to back fire thought the TB. I think it is the timing but not sure. What is your opion on this. Thnaks for the info and help
Old Apr 2, 2008 | 03:33 AM
Drew's Avatar
It doesn't matter on the early EFI cars since all the injectors fire at the same time anyway.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Cleotiz
Jan 6, 2018 08:56 PM
toronto formula
Nov 10, 2015 06:17 AM
86Base
Aug 13, 2015 05:06 PM
