Sluggish IAC motor?
Old May 2, 2008 | 11:58 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Sluggish IAC motor?
'86 2.8: Between shifts, the RPMs stay high for way too longs, and I get into the next gear with the engine turning too fast. Sitting still, I can rev it, and the tach stays up there for more than a few seconds before slowly creeping back down to idle. Sluggish IAC motor? Dirty MAF? I already cleaned out the IAC valve seat and pintle. What next?
Old May 3, 2008 | 10:59 AM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Re: Sluggish IAC motor?
like my twin brother, im stuck too. Is your car easier to kill when you try to take off? MAF is an easy check just disconnect your MAF and if it runs better its that
Old May 3, 2008 | 12:10 PM
Kill? Won't stall at all, just keeps the RPMs up too high for too long. After it calms down, it idles just fine. I will try disconnecting the MAF when the weather cooperates. BTW, after it warms up, and I disconnect the IAC motor harness, it runs GREAT.
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
mdtoren
Aug 16, 2015 05:45 PM
