2.8 help
Old Jul 1, 2008 | 02:21 PM
T215D4's Avatar
2.8 help
This morning i tried to start my car the engine cranks fine but
wont start. i have no check engine light and the car started just fine last night.
Old Jul 1, 2008 | 02:41 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: 2.8 help
Getting fire? What about fuel?
Old Jul 2, 2008 | 02:14 PM
T215D4's Avatar
Re: 2.8 help
i dont think it's getting spark because i can hear the fuel pump.
Old Jul 2, 2008 | 03:14 PM
T215D4's Avatar
Re: 2.8 help
i just looked at my starter and it's covered in oil from bad valve cover gaskets
could that be the problem?
Old Jul 2, 2008 | 03:35 PM
firstfirebird's Avatar
Re: 2.8 help
Like I said on the other site, check you connections at the distributor and your grounds.
Old Jul 3, 2008 | 01:31 PM
T215D4's Avatar
Re: 2.8 help
found this after i got my ignition module tested.
http://www.flickr.com/photos/28252072@N04/2634609122/
http://www.flickr.com/photos/28252072@N04/2633787199/
Old Jul 3, 2008 | 03:15 PM
forkvoid's Avatar
Re: 2.8 help
That plugs into a sensor on the back of the passenger side head. I have no idea what it does. Fan sensor, I think?
Old Jul 4, 2008 | 02:22 PM
T215D4's Avatar
Re: 2.8 help
i just pulled the cap off of my pressure relief valve to see that it was gone
can i swap one over from another fuel rail or do i replace the whole thing?
Old Jul 4, 2008 | 02:55 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: 2.8 help
You got your module tested? Whats the verdict? Does it still work?
What is gone? What was the cap on? You talking about the valve on top of the fuel rail?
Old Jul 5, 2008 | 02:02 AM
T215D4's Avatar
Re: 2.8 help
The module was good. the valve on the fuel rail did have a cap when i took it off i saw that the valve was gone so i turned the key to on and the valve came out along with gas, so i just swapped one from another fuel rail.
I'm getting spark, in the past two days ive replaced the plugs, cap, rotor,
and coil. when i pull a plug out to test it it does spark. i'm running out of ideas and i need this car to run so i can get to work tomorrow.
Old Jul 10, 2008 | 05:25 PM
autoholic's Avatar
Car: 1988 Camaro RS, 1972 Dodge Dart
Re: 2.8 help
How were the plugs? Damp? If so check the oil for contamination with gas. Yes it happened to me. If plugs are ok then check fuses and timing, sounds simple but effective.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
