aluminum driveshaft?
Old Jul 25, 2008 | 01:52 PM
xcel92's Avatar
Car: 92 camaro rs
Engine: 3.1
does anyone make one for the v6 Fbodys or will a v8 one work?
Old Jul 25, 2008 | 02:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: aluminum driveshaft?
V6 and V8 use the same driveshaft.
Old Jul 25, 2008 | 02:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
x2.
However, the 2.5" dia steel one I weighted was only like 12.5'ish lbs. Where the lightest aluminum is rated around 11lbs. Unless you broke yours, IMO that money could be better spent elsewhere.
Old Jul 25, 2008 | 02:48 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
I hear carbon fibre ones are like 6 lbs but also heard they shrink and expand anyone have other info on this?
Old Jul 25, 2008 | 03:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the price of a carbon fiber shaft before you worry about expansion and contraction.
Old Jul 25, 2008 | 03:18 PM
Dale's Avatar
Engine: 350 S-TPI
I only know of one person that runs a CF driveshaft.
And as mentioned, VERY expensive.
Old Jul 27, 2008 | 10:58 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
wouldn't a lighter flywheel be a better upgrade than a lightweight driveshaft? more difficult to install, but it would probably be lighter for less money.
Old Jul 28, 2008 | 12:34 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
how about the prop shaft ? thats a damn site bigger than the drive, and ive seen ally ones around, i guess they must shave a bit of weight ?????
Old Jul 28, 2008 | 12:57 PM
project89's Avatar
u dont need to lose much rotating wieght for it to be usefull, when it comes to rotating mass every lil bit helps. a lighwieght driveshaft and set of aluminum drums are a great place to start., also rims are an very gpod place to drop rotating mass specially if u have swaped on 16 iroc rims they are very heavy rims, swaping to a lighter wheel will make a very noticiable difference.
Old Jul 28, 2008 | 04:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The flywheel doesn't spin as fast as the driveshaft, and is easier to balance.
Prop shaft and drive shaft are the same thing.
Old Jul 28, 2008 | 04:41 PM
[quote=Apeiron;3838410]The flywheel doesn't spin as fast as the driveshaft, and is easier to balance.
how does the driveshaft spin faster than the flywheel? doesn't the flywheel, spinning with the engine make the same revolutions as the engine and the driveshaft, spinning with the transmission, spin slower? well, I guess that depends on what gear your in doesn't it?
Old Jul 28, 2008 | 04:44 PM
project89's Avatar
on a th350 3rdgear is 1.1 ratio same on a 700r4 in third gear the ds is matched to engine speed once in over drive the ds spins faster then the engine
Old Jul 28, 2008 | 05:07 PM
according to the sticky in the transmission forum about the T5 the only time the driveshaft would be spinning faster than the flywheel is in 5th gear, but looking at the top speed thread in the V6 section it sounds like you wouldn't use 5th gear very often if at all for high speeds.
Old Jul 28, 2008 | 05:33 PM
project89's Avatar
4th gear on an auto car it would spin faster then the motor or 5th on a t5
and 5th and 6th on a t56
Old Jul 29, 2008 | 12:46 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Prop shaft and drive shaft are the same thing. [/quote]
ahhh i spose thats where your from and different teminology, accross the pond (UK) the propshaft is trans to diff. driveshaft is diff to wheels. thats how we do it :-)
Old Jul 29, 2008 | 01:59 AM
aurum_duck's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Transmission: 700R4 Probuilt Hardparts
Axle/Gears: G92 3.23
i read something on the critical speed of a OEM 3rd gen driveshaft... swapped in a 4th gen all aluminum... and a whole lot thicker
Old Jul 29, 2008 | 05:55 AM
Dale's Avatar
Engine: 350 S-TPI
That would be a recall on vibrations in 3rd gens. And yes, when you would come in with that problem, they would install a 3"dia alumn driveshaft to fix that.
zsta. Trans to diff is driveshaft. Diff to wheel is an axle.
Yes, every pound helps. But if your spending 100'ish on a driveshaft like I was going to when I first read about it. You can get a new cam for that much. Also, as mentioned.... unless you get the ONE driveshaft that is lighter then the steel 2.5" one... you will actually add weight not loose.
Old Jul 29, 2008 | 12:25 PM
Coyote's Avatar
Quite some time back i bought a CF driveshaft for my V6.
I was considering BMR or ACPT.
Since i was ordering some other parts from BMR i decides to order the driveshaft there.
BMR Driveshafts
When it arrived, i weighed it before i installed it ... came in at 13 lbs ... quite heavy for a CF driveshaft !!!
I should have gone for the ACPT ... but too late ...
Here is a picture of my driveshaft installed.
I think that at Precision Shaft you can also have one made for you ... looks expensive though. But then again ... so was my BMR driveshaft.
Precision Shaft
Somewhere on this website i found a list of weights of common f-body driveshafts :
  • 16 lbs - Stock steel LT1 driveshaft
  • 12.2 lbs - 3rd gen aluminum 1LE driveshaft
  • 12 lbs - LPE aluminum driveshaft
  • 11.5 lbs - Stock aluminum LS1 driveshaft
  • 10 lbs - RK Sport aluminum 1pc driveshaft
  • 4 lbs - ACPT carbon fiber
Old Jul 29, 2008 | 12:31 PM
Dale's Avatar
Engine: 350 S-TPI
I notice on that list it doesnt show the 3rdgen steels. I remember my 2.5" one being around 12.5'ish lbs. Wonder if they ever made a 3" steel?
Old Jul 29, 2008 | 01:22 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Sounds like there should be some further explaining on how you got a 13lb CF driveshaft but the numbers you quoted show the CF driveshaft from other manufacturers at <5lbs with every other aluminum driveshaft also weighing less than your CF driveshaft.
You sure they didn't just wrap some CF around a steel driveshaft and give it to you? Why wouldn't you have just returned it? at 13lbs, what's the point of spending all that money when you can junkyard an aluminum one that weighs less and costs a fraction of what you paid?
Old Jul 29, 2008 | 03:49 PM
Coyote's Avatar
Well, personally i think it is an aluminum driveshaft with CF wrapping around it.
Since i live in Belgium , shipping something like this from the US to me is half the cost ... add to that import taxes ... so returning it would be pointless ... even if i get a refund, i would barely break even (minus 1 driveshaft).
Since Thirdgens are quite rare over here (well all US cars actually) , you can imagine there are none to be found on the junkyards ...
Old Jul 30, 2008 | 12:35 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Are manual and Auto shafts different lengths ?
Old Jul 30, 2008 | 01:39 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, unless your automatic is a TH200C
Old Jul 30, 2008 | 11:42 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
excellant thanks.....hmmmmm smashed ls1 round here somewhere......
Old Aug 8, 2008 | 04:24 PM
RyanKeepsitReal's Avatar
the prop shaft is what GM calls theres driveshafts.....but yes they are the same thing haha
Linson
Oct 24, 2025 02:00 PM
loud91rs
Oct 5, 2015 10:05 PM
