A few questions
Old Sep 11, 2008 | 07:24 PM
86v6CP's Avatar
A few questions
I'm wondering if a 4th gen 3.4 intake would benefit my 3rd gen 2.8 I couldn't see the back so I couldn't tell if it would clear the dist. I just thought it would look really cool and perhaps flow good enough on the 2.8 to spin to 6000rpm. is there any suspension stock for stock that is better than the F41? everything I saw at the wrecking yards says no.
Old Sep 11, 2008 | 08:38 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: A few questions
The intake will not clear the distributor. As far as I know, the stock suspension is it as far as what came on the V6 F-Bodies. Higher end engine packages came with better suspension options.
Old Sep 11, 2008 | 08:56 PM
86v6CP's Avatar
Re: A few questions
I took my calipers with me to the J/Y and measured an '87 v6 with the F41 suspension and an '89 Z28 they measured exactly the same. Is the Iroc equipped with better bars or is the F41 suspension as good as stock gets?
Old Sep 11, 2008 | 09:21 PM
project89's Avatar
Re: A few questions
get urself a set of 1le bars and a wonder bar if u dont already have one.
i put both on my car, and damn what a difference, the wonderbar alone made a nice diff in the frontend of the car
Old Sep 12, 2008 | 03:28 PM
kukerdan's Avatar
Re: A few questions
I can spin my 2.8 right to 7000 in 2nd gear
doing about 80 at that point
(actually its been a few thou miles since Ive done that)
but ive had her to 5.5 / 6 real easy latley
Old Sep 12, 2008 | 03:36 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: A few questions
stock intake flows fine, if you can't spin up to redline and beyond fast and hard, you need to open up the air intake or the exhaust.
When I went to a true side pipe I lost that on mine, so I had to blow the end of the bend out so it also blew straight to get that back.
Also have a super low restrict foam filter with true cold air ram/air.
Old Sep 12, 2008 | 08:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: A few questions
The intake doesnt flow any better, and doesnt clear the dizzy as mentioned. Its also harder to port/debur then your stock.
As for suspension, most is NOT the same. I "think" you could grab a rear swaybar and thats about it.
Old Sep 12, 2008 | 08:55 PM
86v6CP's Avatar
Re: A few questions
OK I'll go with a wonderbar and adjustable shocks. Besides all I have for competition is an SVO with all the option boxes checked weighing in at about 4k lbs.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
