car won't start I need help!!!
Old Oct 19, 2008 | 05:58 PM
chester miller's Avatar
Car: 89 RS
Engine: 2.8
Transmission: auto
I have an 89 2.8 I bought the whole car for 125$$ the guy said it ran when he parked about 2-3 years ago so I brought it home and put a battery on it and it would turn over but won't start so I looked for spark and there was none so I went and bought a new coil and rotor and now I got spark but it still would not start so then I replaced the fuel pump and now I am getting fuel but it still wont start so I took the starter of to see if it needed to be replaced so I refurbished it so now it turns over faster but still does not start if I spray some ether in it wile I am turning it over it will like fire on one or two cylnders but will not start. And that is where I am stuck at if u have any info that I might be missing please help..
chester
Old Oct 19, 2008 | 11:26 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: car won't start I need help!!!
hmm check the distributor and make sure the timing is set right. almost sounds like a bad ignition module. if ur spraying in the intake and its not starting . not enough spark.
Old Oct 20, 2008 | 08:16 AM
Car: 89 RS
Engine: 2.8
Transmission: auto
when I bought the car the dis was out of the hole but we think we have it set right we looked in the book and how much would a moduel be??
Old Oct 20, 2008 | 10:27 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
In my experience you can only get refurbished modules in the parts store -such an important part I wouldn't want to get a re-built one. I would go straight to GM. But first, have you thought of putting on a new idle air control sensor? My car sat for 10 years in this old guys garage (that's why it's so perdy ) without being started and that's all it needed post tune-up. The only other thing you should worry about is rust in the coolant system. I've done 5 flushes and I can't have new glycol in for more than a day b4 it turns brown! lol
Old Oct 20, 2008 | 07:28 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
you might need to tear off the timing cover and see if the timing chain has skipped. I bought mine for $200 and I had a similar story as yours. my timing chain had skipped. its a common problem on these engines.
Old Oct 20, 2008 | 11:35 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
sounds like freeze plugs are rusted and need replaced. antifreeze should not turn brown in 1 day. changed the freeze plugs in mine a while back. after 6 months it looked green as the day i filled it up.
Old Oct 21, 2008 | 01:41 PM
Car: 89 RS
Engine: 2.8
Transmission: auto
hey thanks guys I figured it out it is a wireing problem the guy I bought it from I guess tried to rewire it and he only did it half way. so I am just going to sell it but thanks guy u have helped a lot.
Chester
Old Oct 22, 2008 | 07:49 AM
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
I have a 1989 with the 2.8 L engine and I am selling it. it runs excellent. New brakes, shocks, Struts, plugs, wires, distributor, EGR, O2 Sensor, exhaust from the cat back, interior was changed 90% to black instead of red. Car also has Sun roof that doesn't leak, Power windows, Power hatch back, Power steering, cruise control, A/C and probably more that i haven't remembered. Needs paint job. I am willing tlet it go for $500. I recently bought a 1989 5.0l and am investing into that one to restore. I also have a 5.7L LT1 engine out of a 1994 SS Impala Cop Car that I will also negotiate a price on if needed as well as a radiator. I am going to list the car in the near future but was compelled to offer it to you first.
Old Oct 22, 2008 | 07:27 PM
Car: 89 RS
Engine: 2.8
Transmission: auto
hey thanks mac but I am not prepard to buy one right now and I am going to sell mine first but thanks.
chester
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
