Are the oil pans interchangable?
Old Oct 27, 2008 | 07:33 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Swapped in a 3.4 and kept the 3.4 setup on front of engine. Stripped out the plug and it broke off on the inside and I want to know if a 2.8 pan will work for me.
Thanks in advance!
Derick
Old Oct 28, 2008 | 08:45 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Are the oil pans interchangable?
The 2.8 pan will work. I hear that the 3.4 pans are hit or miss for fitting our k member. The 3.4 block is the same as the 2.8 externally.
Old Oct 28, 2008 | 10:53 AM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Cool thanks! It is a tight fix and I know when I had teh 2.8 in there it wasn't as hard to get it out. So I will be getting a 2.8 pan and use it instead of trying to find a 3.4 pan.
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
