Anyone know how to clean injectors?
Old Nov 6, 2008 | 10:43 PM
Bricktop12000's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Axle/Gears: Stock
Whole fuel system was contaminated in my 92 3.1. Fuel injectors have carmelization in the tips. Is it possible to blow out the injectors? If so anyone know how?
Old Nov 6, 2008 | 10:55 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: Anyone know how to clean injectors?
Get a good BG fuel service. It'll clean the whole system really well and your 3.1 will run like new.
The pros swear by BG, and so do I.
Old Nov 6, 2008 | 11:01 PM
Car: 1992 Camaro RS
Engine: 3.1 V6
Axle/Gears: Stock
BG fuel service? There plugged or somthing. im not getting any fuel to the cylinder. Just rplaced just about everything in the fuel system to underhood and am getting good pressure to the rail.
Old Nov 6, 2008 | 11:39 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
oh, so no fuel's going through them... Well, if they were mine, and had that much sh*t in em I'd prolly just go for new ones. I really don't know the condition or age of yours though.
Old Nov 7, 2008 | 09:51 AM
Car: 1992 Camaro RS
Engine: 3.1 V6
Axle/Gears: Stock
Well the car has been sitting for about 4-5 years. Im trying to rescue it from death. I looked up some new ones and there about 60 a peice. any idea what other injectors would work with the stock fuel rail and connecters?
Old Nov 7, 2008 | 03:08 PM
yellowmaro's Avatar
Car: 1986 Camaro SC
Engine: 2.8, headers, duals
Transmission: auto, 125 speedo, accel coil, k & n
there are good ford injectors that are refurbished on ebay for less than 100 bucks. do a search and you will find them. i did this instead of paying 600 bucks for new gm injectors.
Old Nov 7, 2008 | 03:52 PM
Car: 1992 Camaro RS
Engine: 3.1 V6
Axle/Gears: Stock
Will the ford injectors plug right in or is there any mods needed to do the install? By the the way, do you know what he rating is on them factory? 15# 17# 19# 21#??? This is the first time ive really worked on a fuel injection system.
Old Nov 8, 2008 | 10:20 AM
Car: 1992 Camaro RS
Engine: 3.1 V6
Axle/Gears: Stock
Cool guys, found me a set of refurbished on ebay for a really reasonable price. Hopefully im getting what I pay for.
Old Nov 9, 2008 | 12:10 AM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
The Fords will work without any mods..you will need to reuse the o-rings off your originals.They sit a bit lower(shorter length) but still work without any mods.I believe they are just under 15# for their flow rate.
Old Nov 9, 2008 | 12:12 AM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
i know at advance auto parts we used to have people pulling there injectors and cleaning them with the seafoam solution and then running it through the tank.
Old Nov 17, 2008 | 05:04 PM
91Camaro_RS's Avatar
i bought my new injectors from ebay also i got all 6 for like $200 way better then getting them from a local parts store...they wanted $160 each
As far as replaceing them goes. Its really really easy...I put mine in in about a half hour and i recommend buying all new gaskets for the intake plenum when you take it off because all of mine fell apart when i unbolted everything but once you get the intake plenum off you just unscrew the fuel lines, unplug the injectors, unbolt fuel rail, then pop in new injectors and put it all back together...it seems hard but actually very simple
if you just want to try cleaning them you can take them out and soak them in kerosene for a while...i have never done that but i heard that it works
Old Nov 17, 2008 | 11:21 PM
Car: 1992 Camaro RS
Engine: 3.1 V6
Axle/Gears: Stock
Got a whole set of refurbished injectors on ebay for 85$ free shipping. Put them in yesturday and she purrs. now I just need the air injection ( Smog) pump bracket and im in business. anyone know what other aplications the brackets will match up on?
Old Nov 17, 2008 | 11:43 PM
southbay08's Avatar
Hey there, we specialize in cleaning and " refurbishing" fuel injectors. We also carry the ford design lll fuel injectors. We have 17lb,19lb, 22lb, etc. We flow all of our injectors at 43.5psi. If you are interested, there is a 10% discount for all third generation members. If you go to our website www.southbayfuelinjectors.com just type in the discount code: N665. If you are looking for something that you do not see just give us a call. We will be happy to help.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
