91 3.1 need help..
Old Jan 31, 2009 | 12:00 PM
1991z28camaro's Avatar
Car: 1992 RS Convertible
Engine: 5.0 L 305 TBI
91 3.1 need help..
G'day
The car cranks but does not run . The wife was driving it and she said it had no power and backfires and then dies.
Thanks in advance....
Old Jan 31, 2009 | 10:28 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Re: 91 3.1 need help..
G'day to you too.
I can think of a few reasons for your problem, but first off - how many miles on the car? The rationale is that you could be having a vacuum leak - which is pretty common on these cars as the intake manifold gaskets, etc. get brittle.
The other obvious question is do you have proper fuel pressure and good spark? A plugged fuel filter, bad injectors or bad fuel pump will also cause loss of power. In addition, when was the last tune-up? What is the timing set at? This gets back to how many miles - is the timing chain loose, did it jump a tooth?
Also, what condition is the cat converter in? If you have an AIR pump and it is not working/leaking plus the cat not working, that will definitely cause loss of power!!
So, many causes, many solutions. Just need specifics to help you out.
Old Feb 1, 2009 | 04:28 PM
GTA50
Miles 150,00
Spark good
Fuel filter changed around 18 months ago
Tune up around 24 months ago ( plugs , cap , rotor and leads replaced also the ecm was replaced)
Cat ..does not have one the guy who had it before me cut it out and put a piece of pipe in its place.
Fuel injectors were replaced 12 to 16 months ago .
Old Feb 1, 2009 | 09:41 PM
GTA50's Avatar
To me the backfire and dies and loss of power would suggest a vacuum leak. On the other hand, no cat and I'm assuming no O2 sensor would also lead me in that direction. So.......do you have an oxygen sensor or was left left abandoned by the previous owner?
Old Feb 2, 2009 | 07:08 AM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
O2 sensor
Old Feb 2, 2009 | 04:24 PM
o2 sensor was replaced 2 and half years ago.
Old Feb 2, 2009 | 10:59 PM
GTA50's Avatar
Still could be many things. You said that spark was good I believe. Have you checked for sufficient voltage to the injectors and fuel pressure being adequate (I know you said the injectors had been replaced - still could have a faulty one). Also, check the injector fuses.
Assuming those are fine, I would next look at the EGR and see if perhaps the gasket is blown through. Alternatively, check if the EGR is functioning properly.
I would also be tempted to do a full tune-up. On these cars, 1 1/2 to 2 years is a long time I have found. Corrosion and/or moisture in the cap, etc....
Old Feb 2, 2009 | 11:04 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Did it gradually happen, or did it just start doing this one day?
Old Feb 3, 2009 | 05:31 PM
It was playing up for about 2 weeks before it died , also I forgot to say when it changed into 4 th it got a real bad vibration in the motor .
Old Feb 3, 2009 | 08:30 PM
Car: 1991 Firebird
Could you have picked up some crappy gas somewhere?
Throwing any codes at you/check engine light?
When was the timing chain done? Could it have jumped timing?
Got a fuel pressure gauge you could use to make sure its ok? Might be the fuel pump....
Old Feb 4, 2009 | 01:45 AM
nd4spd42085's Avatar
Car: Formula/RS
Engine: 5.7L/60 degree
Transmission: both 700r4
Axle/Gears: 2.73 lsd and 3.23, respectively
Originally Posted by 1991z28camaro
G'day
I'd say check the intake gasket first, it's cheap and easy to replace and cause symptoms such as these.... from what I have heard in this organization anyways... not had the pleasure myself...
it doesn't run now at all?
a blown coil couldn't cause this could it?
Old Feb 5, 2009 | 08:38 PM
It is coming up with code 22 tps..
I need to go and buy a fuel pressure gauge and a multimeter this weekend..
Old Feb 5, 2009 | 08:40 PM
No but it turns over and thats it.....
I was getting good spark before it died...
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
