average lifespan for a 3.1L V6 '92 rs?
Old Feb 8, 2009 | 05:25 PM
industrialphd's Avatar
hey i'm about ready to pull the trigger on buying a 1992 RS with a V6 A4, but i have one reservation, and that's the mileage. it's got 183k miles on it, with, as far as i know, original factory components.
how long will this thing last? assume it'll be a daily driver for about 18 months, and assume worse case from it's previous owner.
Old Feb 9, 2009 | 08:34 AM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: average lifespan for a 3.1L V6 '92 rs?
it will last longer then the car it self lol i can tell u that much everything else will stop but the engine will run forever just check the fluids and do a tuneup and ur good for a other 200xxx miles lol or to the wheels fall off
Old Feb 9, 2009 | 09:26 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Generally speaking a 3.1L V6 will last until the car is purchased by someone who knows how to swap in a V8.
Seriously though, it should be just fine as long as it's had regular maintenance. The V6 I just pulled from my 92 had 106,xxx on it, and it ran just fine. I know that me and the last 2 owners of the car didn't baby it, but we did the normal regular maintenance on it.
Like Firebird said, do the usual tuneup stuff, ie change fluids/cap/rotor/plugs/wires, and it should run just fine for a long time as long as the engine isn't making any funny noises now.
Old Feb 9, 2009 | 05:29 PM
roger199013's Avatar
Car: 92 camaro RS
Engine: 3.1v6 soon to be 3.8 grandnational
My friends had 250,000 miles last i checked. just change the oil and don't let it overheat and it should last 300k+ miles. but expect to change a few things like sensors and water pump.some things will eventually get worn out.
Old Feb 9, 2009 | 07:16 PM
auto-x1990RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Axle/Gears: 3.23 open diff
mines on 230k miles, and it just finally died (hard cornering caused oil starvation, spun main and rod bearings). technically, she's not completely dead seeing as i can still start her up, but i'm not driving the old beast till i rebuild the bottom end
Old Feb 10, 2009 | 04:10 PM
pontiacguy1's Avatar
I've got 210K on my 1992 3.1 V6, but blew a head gasket. No biggie, though, It should be back up and running in another couple of weeks. I used to use a 75 shot of nitrous on my engine all the time. I haven't used the nitrous in about 5 years, but never had any trouble with it. Mine looks good and runs fine (except for when the head gasket blew). I can still get about 30 MPG on the interstate.
My dad has a 1991 Sonoma ST 2.8 V6 5spd that has 355K miles on the odometer, and it has never had anything major done to the engine. Regular maintenance, and some items like alternator, water pump, exhaust gaskets, the occasional sensor....
Elephantismo
Feb 13, 2019 12:51 AM
HoosierinWA
Oct 7, 2015 10:15 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
okfoz
Sep 22, 2015 03:37 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
