More 2.8 Problems
Car: 89 Firebird,98 Z28 Vert
Engine: 2.8L,LS1
Transmission: 700r4,4L60e
More 2.8 Problems
Hi,I have a 89 firebird with problems,go figure lol,anyways,I replaced the lifters do to a bad lifter.I adjusted the valves,and now it runs rough and stalls out.Parts that was replace b4 I bought the car are.Egr,o2,maf,tune up,alt,fuel pump/filter,fuel reg,and ac comp.The car has 155,000 miles on it, did the timming chain set the timing and stumped on what to do.Had my friends look at it and they cant figure it out either...Any help would be great full..Thnks Gary
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: More 2.8 Problems
sounds like my 2.8 wanting to sputter..got a cure for mine though..its coming out tomorrow..makes you want to blow the engine up..no telling how much i have put in the motor and still acts up..make sure the head gasket isn't leaking...and if it isnt check the exhaust manifold,,and double check all vac lines to throttle body..
Car: Many
Engine: Several
Transmission: Automatics
double and triple check. thats my bet your problem is. i changed the wires the other day and got the wires mixed up. its easy to do. just label your wires so it easier. GL
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Well, if you set the timing right, my guess would be a bad valve adjustment, but you would need to get a compression gauge to confirm this. Should be around 140-160 PSI, IIRC (been a while since I had my 2.8, you know). Either way, you should check your valve adjustment to make sure you aren't floating any valves. Does the engine make a sort of high-pitched whine when turning over (actually, the sound is kind of hard to describe, but once you've heard it you will ALWAYS know what it is)? That's due to lost compression.
Engine: 2.8L,LS1
The cae starts with no strange noise.I do have to give it gas to start.I need to do idle relearn buy cant do it yet.Ill do a comp test this weekend.
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
are the valves over tightend and letting gasses getting by instead of compressing in the combustion chamber? also check the lower intake/upper intake gaskets. a leak there will be a huge vaccum leak and cause the engine to run rough.
