Do you have an underdrive pulley?
Old May 22, 2009 | 09:47 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Because I want to buy one. My serp belt is not long for this world so I figured if the belt needed to be replaced this would be a good time to buy one. I know ASP, and jet make them. I would get it at summit but estimated shipping date is 7/11/09
One question I couldn't seem to find a straigt answer to in my search of previous threads is, how well will the car charge? It says on ASP's website full charge is 900rpm, which doesn't seem too bad, if it's correct. my car idles around 6-7K so any gas would charge the battery. I'm just lokin for the opinions of those who have had or still do have them.
I've seen some of you say you took the one you bought off so I hope someone has one they'll sell me.
Old May 22, 2009 | 01:26 PM
xcel92's Avatar
Car: 92 camaro rs
Engine: 3.1
Re: Do you have an underdrive pulley?
I've had the crank pulley from asp on mine for about 2 years now and i haven't had any problems with it keeping the battery charged.
Old May 27, 2009 | 10:12 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Ive had one for 4 years and no charging issues.
Old May 27, 2009 | 11:25 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Thank you those of you who replied, guess people who have them don't have problems with them.
I'm in a deal with grimmcs to trade pulleys with him.
Old May 27, 2009 | 03:00 PM
ckyfreak2010's Avatar
get the underdrive pulley, i got one and its the best investment i made, it does not affect charging at all, the UD crank pulley definitely freed up some HP and MPG i highly recommend it
Old May 28, 2009 | 09:40 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
I'm making a deal for one right now. Thank you for the encouragement.
Anybody know what size belt I'll need? My car still has the AIR pump and A/C. I've heard like 3 inches shorter than stock, but what would that length be?
Old May 28, 2009 | 10:52 AM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Crank and alt pulleys for about 6 years now. I've had battery issues ever since. I have to change them out about every year. Lame. Seems like just the crank pulley is the way to go....
Since you are trading, just trade the belt too.
Old May 28, 2009 | 11:04 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Yeah, The alt pulley makes the alternator spin too slow. I'm only getting the crank UDP. I'll have to see if he'll send the belt or if it's any good.
I've got a question. How does the tensioner work on these cars?? I've looked at it and it doesn't see obvious to me. what do you gotta do to get the belt loose?
Old May 28, 2009 | 08:31 PM
Car: 1991 Firebird
If its not any good, he should be able to at least get the numbers off it.
Take a ratchet to the tensioner. 15mm (i think?) socket, turn clockwise about half a turn, belt is loose.
Old May 28, 2009 | 10:07 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Yeah, that's what he doing.
Hmm, guess I'll have to get a better look at it tomorrow, sure I'll figur eit out.
Old Jun 1, 2009 | 09:39 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
OK, i know the tensioner's gotta be that thing right next to the alternator but I cant figure out what to do to loosen it. Is it spring loaded like the ones on newer GM cars? What bolt do I gotta loosen? A pic would be great..
Old Jun 1, 2009 | 10:28 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
You don't have to loosen any bolts. Just twist the bolt in the middle of the tensioner pulley and rotate counter-clockwise. It will lift right up and release the belt tension.
Old Jun 3, 2009 | 01:59 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
I got the pulley installed today and love it so far. The volt gauge stays at around 14 even at idle, so I guess I wont have charging problems. The power difference is also noticeable.
Thank you Grimmics, your pulley will be coming in the mail shortly.
Oh, and I found that the tension is about the easiest thing to use ever, lol.
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
