"Decel Valve"
Old Jul 16, 2009 | 02:31 AM
GiovanniP98012's Avatar
Car: 1988 Camaro RS T-Tops
Engine: 2.8L V6 TPI
"Decel Valve"
There is a part that took me 6 hours to find what it was i went to 3 shucks and 2 chevy dealerships to find out the broken and "poor man Fixed" was a deceleration valve that is discontinued and isnt for sale anymore... So i was wondering where can i get one that will work for my car.
The guy said that it is only in the manual V6s and it maybe in V8s but he wasnt sure...
Please help thanks
Old Jul 16, 2009 | 08:37 AM
pontiacguy1's Avatar
Re: "Decel Valve"
Never heard of the 'Deceleration Valve' before. Every car has an idle air control valve, and that usually has the function of regulating the idle on a car. Why would another valve be needed?
No vehicle I've ever worked on had a valve like that on it. I notice that you are from Washington State... Could that be a california emissions thing?
Old Jul 16, 2009 | 12:51 PM
Engine: 2.8L V6 TPI
Re: "Decel Valve"
i looked in a chiltons manual and it says it came with the car and the dealership says it did too...
What exactly does an idle air control valve do?
Old Jul 16, 2009 | 06:16 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: "Decel Valve"
The Decel valve shunts extra air into the intake from the air filter to help control that burst of gasoline and hydrocarbons that is generated when a driver with a manual transmission releases the gas suddenly and steps on the clutch, whether to stop or change gears. At least, that's what my FSM says. I have never seen one, but then, I've never looked, either. And yes, it was only in the manual trans-equipped cars.
The IAC is the thing that acts as the idle speed screw/choke plate on a carburetor by opening and closing to regulate the amount of air that is bypassing the throttle plate at idle.
What is wrong with your car that you think you need a Decel valve?
Old Jul 16, 2009 | 06:46 PM
Engine: 2.8L V6 TPI
Re: "Decel Valve"
It was broken and someone tried putting silicone all over it.
It was just all messed up i bought one for another car and i think it will all work out.
I just have to make some hose lines to fit differently because the hoses attach differently on these ones.
I have leaks and one of them was there but i need to find the other ones haha
My car just when i start it doesnt work till i warm it up like it dies over and over and then once i warm it up it idles really high like 15 or 20 but it irradically goes up then goes back to 10 then slowly up to 20 and repeats
But yea im just trying to get the last out of this car till i drop in a 327 i bought the car for 600 and now ive spent about 1200 so for a running pretty good shape car it was just alot of work haha
Old Oct 1, 2011 | 07:54 PM
thomaslog's Avatar
Car: 87 camaro rs
Re: "Decel Valve"
I am also looking for a decel valve for my 87 camaro. it is my first car and i need it to pass smog so i can finally drive it, it has a ton of vacuum leaks including that valve and i havnt been able to find it anywhere
Old Aug 10, 2012 | 08:51 AM
partimechanic's Avatar
Re: "Decel Valve"
Could I get a picture of this valve and location please?
Old Jul 31, 2019 | 11:46 PM
Devin Riddle's Avatar
Car: 1986 Firebird
Engine: 2.8
Transmission: 5 speed
Re: "Decel Valve"
Arrow on left is pointing at decel valve arrow on right points to air pump. (No hose attached just venting into engine) Circled is a hose hanging from middle connection of decel valve Top hose meets the back of intake and turns into brake boost on other side Bottom hose missing I have a very high idle after pressure washing engine just tryna figure out where those hoses are supposed to go and if they could be the cause of the vacuum leak
Badass355ciz28
Sep 28, 2015 08:31 PM
greenyone
Sep 2, 2015 03:39 PM
wjbecker
Mar 13, 2004 06:21 PM
Craig Moates
Mar 5, 2004 09:58 PM
LBSZ28BLOWN
Nov 14, 2002 06:37 AM
