89 2.8 5peed transmision mount
Car: 88 IROC Z
Engine: 5.7
Axle/Gears: 3.27 9 BOLT POSI
i have an 89 camaro 2.8 with a 5 speed and only that year came with a different round transmission mount that i cant find anywhere.dealer has it for 180.00 plus tax and special order. is there anywhere else i might find it? is there a better solution? thanks
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: 89 2.8 5peed transmision mount
hit the junkyard, find yourself an AT x-member and use an AT mount
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I have a 92 that came with a V6 and a T5 and had that same "donut" mount. I bought an auto crossmember off ebay and a regular mount at Autozone. Total cost of everything was $45 and it all bolted right in place.
Car: 89 formula firebird
Engine: modified 305 tpi
Transmission: 5 speed manual
Axle/Gears: 3.45 borg warner rear end
you guys are life savers... this has been pissin me off for days, words cant even explain it
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
it can be a v6 crossmember if it's off an automatic transmission car
here's a thread I started on the subject...just a couple of weeks ago. https://www.thirdgen.org/forums/v6/6...all-v6-t5.html
Car: 89 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 5Speed
sorry probs should have clarafied, there are only v8 auto's in the junkyard 82 i think can i grab the cross member off that?
I just looked up the parts numbers for 1982 and 1989, and they are different, but the chances are very high that either would work. Just to be safe you might want to try to find one off a later f-body, put out a call from one here, or look on ebay
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
are you aware the 82 camaro uses the exact same tranny mount as the 89?
I said it would probably work, but didn't make any promises
That same transmission mount is used in a multitude of RWD GM vehicles. Are you going to suggest that the kid go get a crossmember out of a '77 Buick? Because it uses the same mount!
dont be idiotic.
The frame didn't change for the entire run of third gens, so there's no reason why the crossmember wouldn't work
I said to be safe he should use a later crossmember, but if he has one handy and cheap, give it a try. He has to buy the mount either way.
The frame didn't change, but the crossmember mounting points in it did.
Springster
Sep 13, 2015 01:38 PM
