3.1 ecm need help.
Old Oct 15, 2009 | 06:35 PM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
3.1 ecm need help.
how do you make the 3.1 ecm relearn its idle if the car wont stay running?
Old Oct 15, 2009 | 06:56 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: 3.1 ecm need help.
https://www.thirdgen.org/forums/v6/1...dle-learn.html
Old Oct 15, 2009 | 08:14 PM
legendofkane's Avatar
Car: 1992 CAMARO RS
Engine: 3.1 V6 STOCK
Transmission: AUTO 700R4
why does the car shut off?,,any codes being thrown,,if not possible vac leak,no fuel or spark..how long does it run before it stops..
Old Oct 16, 2009 | 11:01 AM
fuels good that im positive off. spark should be good but not poitive. all vaccum lines are good and manifold bolts are tight. it runs for about 2 seconds then dies
Old Oct 16, 2009 | 12:09 PM
Car: 1992 CAMARO RS
did you check the ecm for any codes?...if it was vats it wouldnt do anything so ur good on that,might be weak spark,the gas is extinguishing the spark and causing it to die maybe,,pull all plugs,check color and wear,,if thy r not bad, gap to 45 thousandths (.045) and be sure to check the tbi bolts but that would be a bad leak to only run 3 seconds,u would hear that maybe if some one else turned the key while u listened.Please update us on what u did..
Old Oct 16, 2009 | 01:52 PM
ya i have till tuesday to figure it out then its going to a shop either way ill let u guys know what it is. ive eleminated a ton of stuff. im putting most of my money on it bieng a spark issue i found my voltmeter today so ill be out there tmrw troubleshooting. ive replaced everything from distributor to spark plugs so im guessing i have a short or a broken wire inside the insulation bc everything looks to be good.
Elephantismo
Feb 13, 2019 12:51 AM
thunder57
Nov 7, 2015 02:28 PM
2012sergen11
Oct 13, 2015 07:38 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
cking99
Sep 22, 2015 11:33 AM
