the n/a motor
Old Nov 23, 2009 | 12:23 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
the n/a motor
ok so we have the turbo guys but what about the guys i am going to do my motor on a n/a buled can i put a 3.4 cam into my 3.1 will a set of 2.8 ho fiero heads give me more power just tell me what will work and what will not no fwd stuff tho i work at a junkyeard so let me now aspe
Old Nov 23, 2009 | 12:31 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: the n/a motor
Punctuation is a good start. the fiero heads are the exact same as all 85+ 2.8 heads, as well as 3.1 and 3.4 heads. If my memory serves me correctly, the cams are the same as well. search through the posts on here about wanting more power or building up an engine. this has been posted time and time again.
Old Nov 23, 2009 | 06:23 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: the n/a motor
Start with the stickies at the top. Anything involving fwd heads is good reading...
Old Nov 23, 2009 | 08:42 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: the n/a motor
Hate to break it to you, but if you're wanting to tune these v6's for N/A the best upgrade available is the top end swap to that of a 2000+ model year 3100 or any year 3400, because finding aftermarket engine upgrades for these engines is hard, as next to nobody makes them.
As for the cam it would mainly depend on style of what you have and what you're looking at, ie. hydraulic flat tappet to hydraulic roller would want new lifters, and you may very well have to get new pushrods as well.
Old Nov 25, 2009 | 12:52 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: the n/a motor
FWD stuff is where the power is. I managed to get about 320 HP/300TQ with a cam, headers and a little porting from a '04 3500 V6.
That entire engine will soon be in the '89 in my sig...
Old Nov 25, 2009 | 04:06 PM
Engine: 3.8, 3.4
Re: the n/a motor
On a complete 3500 engine, or a hybrid build with 2.8/3.1 block?
Cause I've been contemplating how much power I'll make after my hybrid build up, I'm getting a 3400 top end and putting it on a 2.8 block, along with a big race cam designed for 3400s, I'm hoping for 250 hp and torque or so, think it'll happen?
Old Nov 25, 2009 | 08:18 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: the n/a motor
I say its possible. I believe I was around 230 at the crank with a big cam and iron heads.
Old Nov 26, 2009 | 12:04 AM
Engine: 3.8, 3.4
Re: the n/a motor
With original heads and intake manifold o.O? If so I might hit 300....
Old Nov 26, 2009 | 07:45 AM
Car: 91 Camaro
Re: the n/a motor
"original" heads...with a lot of porting and polishing. The chassis dyno never showed good numbers for me but I think that was do to other factors. The 1/4 mile times and guestimated weight of the car gave me figures pretty close to what I had guessed at for hp. My best 1/4 mile pass wasn't with the original upper intake manifold.
Old Nov 28, 2009 | 12:24 PM
Engine: 450HP 355
Transmission: TH350
Re: the n/a motor
complete 3500. I had the engine in my Z24 cavalier and ran 13.07 @ 2800lbs weight with a 5 speed.
With the gen3 top end that is possible, if you can afford it i would pick up a set of heads from wot-tech. His ported 3400 numbers are very nice and will make a good bit of difference VS stock heads. Forced Firebird is selling flat tappet cams for the gen1 engines. I'm sure he can hook you up with a custom grind that'll make the best use of the aluminum heads.
a friends 3400 v6 in a '92 Sunbird 5 speed put down 224 WHP / 231 WTQ with some mild ported heads and a .506 lift/270 duration single pattern cam with stock log manifolds. That's 258HP/266TQ at the crank.
Old Nov 29, 2009 | 04:47 PM
firstfirebird's Avatar
Re: the n/a motor
My name is "firstfirebird" here Mr. Dave ;P
Old Nov 29, 2009 | 10:46 PM
Engine: 450HP 355
Transmission: TH350
Re: the n/a motor
you should change that.. lol
Old Dec 1, 2009 | 12:16 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: the n/a motor
see thatsthe bad part i would love to do a 3500 but this is my dd camaro
i need it every day but i would like to find some way to git abot 250 na and then maybe some day a paxton superchager
Old Dec 1, 2009 | 11:37 PM
Car: 91 Camaro
Re: the n/a motor
A. you wont be able to make to modifications needed to see 200+ hp and drive the car everyday while you are modding it.
B. to achieve 250 hp n/a, you most likely would need to raise your compression ratio considerably (think 10.5:1 or so). This would not be boost friendly...no paxton down the road unless you lower the CR, again. I had nearly 11:1 compression with custom pistons in my motor, a big cam and I don't claim to have reached 250hp. I think I was fairly close but probably more like 230 for me.
Old Dec 2, 2009 | 01:15 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: the n/a motor
i was just kinda throing a hp # out there i would be hapy with 200 but i am going to boost my motor
Old Dec 3, 2009 | 09:21 AM
drdave88's Avatar
Engine: 6.0L
Re: the n/a motor
What engine do you have in this car currently? your post says 3.1, but the info by your name says 3.4. 200 should be attainable with most of the bolt ons, a cam and a tune. Ive got that done, plus a couple other things, but no tune and im probably sitting in the 180s or so. Ive got a ton to gain by a tune since im running so rich right now.
Old Dec 9, 2009 | 12:37 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: the n/a motor
ye i need a tune to im runing way rich i have to clean the plus every week
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
