Check Engine Light issue
Old Jan 10, 2010 | 05:54 PM
nathanec's Avatar
Car: '92 Pontiac Firebird
Engine: 3.1 V6 LH0
Transmission: Automatic
Axle/Gears: Stock
Ok I had to replace the starter on my '92 and after we got everything hooked up and I fired it for the first time the check engine light came on and stayed on now i've took it over to firestone to get it checked but the person who dose the computer check wasn't there so the guy at firestone and I thought it may have just been we tripped it up while working on it so he suggested reseting the system by pulling the battery letting it sit and then plugging it back in so I did this after consulting the family member that helped me work on it no change I'm taking it back over to Firestone on tuesday when the person will be there as perhaps it just needs to be reset if its not though do you guys have any ideas what I can do to get this cleared up?
Old Jan 17, 2010 | 01:48 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Re: Check Engine Light issue
cant help without more info, is it acting up? dont you have a code scan tool or a paperclip? lol
Old Jan 17, 2010 | 01:50 PM
nathanec's Avatar
Engine: 3.1 V6 LH0
Axle/Gears: Stock
that one was due to us breaking the pig tail on the knock sensor it was giving code 43 now that we got it fixed that went away but i'm getting a intermittent ses light that's giving code 45
Old Jan 17, 2010 | 01:59 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
45 is a rich exhaust condition sensed by the O2 sensor. Possibly the O2 sensor itself.
Old Jan 17, 2010 | 02:01 PM
nathanec's Avatar
Engine: 3.1 V6 LH0
Axle/Gears: Stock
my question is right now with that code poping up is it safe to drive back home to El Paso from Austin?
Old Jan 17, 2010 | 06:23 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Yeah its safe, the only foreseable problems that I can think of are hesitation, poor fuel economy, and just general acting up when accelerating. But when you get there you def. need to get a new O2 sensor. Its safe for a while, but after so long a bad O2 sensor can foul out your CAT, so just get it done eventually. I drove mine around with a bad O2 sensor for about 2 weeks before I got it fixed, so yeah it should be safe.
Old Jan 17, 2010 | 06:25 PM
nathanec's Avatar
Engine: 3.1 V6 LH0
Axle/Gears: Stock
thanks for the info on that
Old Jan 17, 2010 | 06:27 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Anything I can do to help. Good luck with it! And don't worry a new O2 sensor is like 30 bucks. But a new CAT is a bit more, so just be sure to replace it. An easy way to check for a bad O2 sensor is to smell your exhaust. If you smell rotten eggs or sulfur, then thats a tell tale sign of a bad O2 sensor.
Old Jan 17, 2010 | 06:31 PM
nathanec's Avatar
Engine: 3.1 V6 LH0
Axle/Gears: Stock
heh yeah but do i want to have my mom put more money (she bought the battery starter and pigtail) into it or wait till i get home, hmm... tough question
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
