odd idle issue
Old Jan 10, 2010 | 11:09 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
odd idle issue
I have a 1985 2.8, and if it idles for a few minutes, it'll throw a check engine light and Idle rough., put it in gear and drive around the block, and it goes away almost immediately. I haven't had a chance to run the codes yet, any Ideas of what to look into?
Thanks-
Eric J.
Old Jan 11, 2010 | 05:47 PM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
Re: odd idle issue
First you might want to find out what code its throwing but if I had to guess I would say your TPS (Throttle Position Sensor)....
Let us know what code it gives you....
Old Jan 11, 2010 | 06:31 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: odd idle issue
it's he 02 ur running rich and then once u drive the car it's fine or you have and open injector
Old Jan 11, 2010 | 06:44 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: odd idle issue
could be a stuck IAC....running it lean, making a miss. Check the codes before anything.
Old Jan 11, 2010 | 07:23 PM
ericjon262's Avatar
Re: odd idle issue
thanks, I'm gonna check the codes in just a few minutes, I'll let you guys know what comes up.
Old Jan 12, 2010 | 09:51 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Re: odd idle issue
mine did the same thing, it was the TPS.....and i just adjusted it about a month prior to all my idle problems.....got a new IACV and a PVC valve and it messed it all up
Old Jan 13, 2010 | 01:58 PM
ericjon262's Avatar
Re: odd idle issue
code 13 and 44;
13, oxygen sensor circuit.
44, lean exhaust.
I know the car has an exhaust leak, so that's part of the problem. now just to get an o2 sensor and new manifold gaskets, or headers and be done with it!.
Old Jan 13, 2010 | 02:27 PM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
Re: odd idle issue
No s***....I think my 02 sensor is taking a dumb but its not throwing codes out!!!
ERRRRR.....
Old Jan 13, 2010 | 02:45 PM
Engine: L98 494hp
Re: odd idle issue
yes the exhaust leak could be a problem.....change that and the sensor....also keep in back of mind that if it does it again it could be a air leak.....like intake gaskets.
Old Jan 13, 2010 | 06:34 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: odd idle issue
I'd replace the sensor first... Seeing as how the code 13 means it's missing, it's no wonder why the engine is throwing the code 44, which also means constant low voltage coming from the O2S (<200mV is less than 300mV, is it not?).
Where exactly is the exhaust leak? If it's before the O2S, then fix it. If it's after the cat (or just after the O2S in general), don't worry about it until you get the O2S straightened out.
Old Jan 13, 2010 | 08:08 PM
ericjon262's Avatar
Re: odd idle issue
I'm not positive where it's leaking, but it sounds as though it's closer to the manifolds. I need to do more investigating.
thanks-
Eric
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
