3.4 Fourth Gen parts car, good idea?
Old Jan 31, 2010 | 12:56 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
I might have the chance to pick up a fourth gen 3.4 camaro from a junk yard. it has 219k miles and an automatic transmission. so what all parts could i use off of it for my '86 2.8 camaro. I know the engine (which will have to be rebuilt), the drive shaft, and the rear axle, but what, if anything, else?
Old Jan 31, 2010 | 01:15 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: 3.4 Fourth Gen parts car, good idea?
Depends on what they want for it vs what they want for what you're going to use off it. You can change out the dash & center console as well, but I never thought it looked right in a 3rd gen.
Old Jan 31, 2010 | 04:20 PM
Car: '86 SC
Engine: 2.8
I agree with you about the dash, but i meant mechanically. Are there any more mechanical parts other than the ones that are stated in my first post, such as suspension components if they fit and are an improvement over stock. And how difficult would it be to swap an entire 3.4, ecm and all, into my car? i have read the 3.4 swap boogie, but it describes a swap using the original ecm.
Old Jan 31, 2010 | 05:58 PM
bl85c's Avatar
Car: '85 maro
What year is it? If it's new enough to have LS1 brakes you could swap those over too. You really don't want to get into the front suspension, too much fabrication. If you're grabbing the motor & ecm you should drop the trans in too. Way easier to reprogram an E-trans than older stuff.
Old Jan 31, 2010 | 06:51 PM
firstfirebird's Avatar
Whatever you do DO NOT use that ECM. I sell swap harnesses for the 4th gens to use 7730 and 7727 ECM's lol since they have no tuning options. The 93 trans is a re-badged 700r4.
EDIT: If it's a 3.4, then it can't be an LS1 3.4 ended in 95 (LT1 days).
Old Jan 31, 2010 | 07:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The only thing in the drive train worth getting is the engine. Skip the drive shaft as it won't bolt into a 3rd gen. Skip the rear unless you want to purchase rims with a different offset (4th gen rear is wider). The trans is a E setup, so requires a controller.
The brakes are no better then the 3rd gen brakes (which always require an upgrade).
If the seats are decent (at 219K, I doubt it) they would be worth getting.
So, we are back to the engine, which after a rebuild is a decent upgrade from the 2.8l setup.
RBob.
Old Jan 31, 2010 | 07:09 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Depending on the price, use what you need and part it out.
4th gen rear, console, dash, seats, and body panels can all be easily resold. Then you can repay the cost of the swap!
Old Jan 31, 2010 | 11:41 PM
bl85c's Avatar
Car: '85 maro
Garbage iron calipers then. Weren't you working on e-trans control using an older obd1 ecm? Any luck? The trans would still be worthwhile if he had a way to control it.
Old Feb 1, 2010 | 03:11 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
what about the overall condition of the car? it does have 200k+ miles on it....
i think youd have to get a good overall inspection of the car and see if its worth it.....does it run / can you start it up?
Old Feb 1, 2010 | 09:38 PM
bl85c's Avatar
Car: '85 maro
It's in a jy so I don't think it runs. He already knows to rebuild it.
Old Feb 2, 2010 | 06:51 PM
Car: '86 SC
Engine: 2.8
Thanks for all the input, but my grandad blew the engine in his truck ('98 GMC Sonoma 2200 4cyl) the other day and fixing it has become the priority. So the junk van i was going to use as a trade is going to fixing his truck.
Linson
Aug 21, 2015 02:12 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
