FINALLY!! the 3.4 is in the car WOOT
Old Feb 28, 2010 | 07:42 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
TADA!!
Gotta buy a bunch of parts for it this week but shes in and bolted down...whatcha think?
Attached Thumbnails FINALLY!! the 3.4 is in the car WOOT-motor-car-1.gif   FINALLY!! the 3.4 is in the car WOOT-motor-car-2.gif
Old Feb 28, 2010 | 09:01 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: FINALLY!! the 3.4 is in the car WOOT
The underside lighting is a nice touch. I like it. Now you need to get the rest of the engine bay to jive.
Old Feb 28, 2010 | 09:13 PM
Pillsbry10's Avatar
when i finally get it to move under its own power itll be off to paint. the poweder coat on the motor wont stand out as much once its painted. it is pretty bling in there lol more so in person
Old Feb 28, 2010 | 10:59 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
I don't normally like that intake manifold, but that looks nice!
Old Mar 1, 2010 | 11:33 AM
Pillsbry10's Avatar
I think that intake looks way better coated than on any 4th gen. I've seen. Any body know where I can get custom throtle cables?
Old Mar 15, 2010 | 07:13 PM
Pillsbry10's Avatar
a few more things bolted on, almost time to sent my injectors off for a test and clean hopefully will know something back on that soon... cap rotor and plug wires will be here tomorrow. whoopie
*** notice dizzy in the background** lol
Old Mar 16, 2010 | 09:07 PM
Pillsbry10's Avatar
and the new msd toys have arrived
Old Mar 28, 2010 | 04:38 PM
Pillsbry10's Avatar
after test fitting the fuel rail it looks like i might actually have enough room to get the fuel lines connected. going to have to come up with a creative bend though. any suggestions?
Attached Thumbnails FINALLY!! the 3.4 is in the car WOOT-fuel-rail.jpg   FINALLY!! the 3.4 is in the car WOOT-fuel-rail-2.jpg   FINALLY!! the 3.4 is in the car WOOT-fuel-rail-3.jpg
Old Mar 28, 2010 | 06:42 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
looks like probably bend them up then come over the block or up then around the dist. or something of that nature.
Old Mar 28, 2010 | 06:45 PM
Pillsbry10's Avatar
I need to go out there and see if maybe they will squeeze in there with the stock bends... But i'm pretty sure they won't
Old Mar 28, 2010 | 07:20 PM
Pillsbry10's Avatar
well check that out...turns out with a little bit of bending i think i can make the stock lines work...who wouldve thought
**thanks to GM for being Cheap and re using pretty much everything from the scrap bin from year to year
Old Mar 29, 2010 | 10:19 PM
Pillsbry10's Avatar
well it was a bitch but the lines are connected...ill probably change them at some point i dont really like the bends the way they are not to mention they block a lot of the bolt heads. getting the intake bolted down was tricky. however everything is connected and i have fuel pressure(almost shot me in the face). everything is primed and ready..just waiting on the FPR to get here tomorrow and once i put it on its time to see if it starts. wish me luck
Old Mar 30, 2010 | 09:38 PM
bl85c's Avatar
Car: '85 maro
You need to find a way to clean that up a little. Kinda distracts from that nice candy manifold...
Old Mar 31, 2010 | 07:57 AM
Pillsbry10's Avatar
I'll prob wait till it's broke in to change that around but I agree it doesn't look good. It did start though
Old Mar 31, 2010 | 08:55 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Looks good in there! The 3.4 is a great motor. I've been stuffing it with 15 lbs of boost for years with no problems. What kind of rocker arms are those?
Old Mar 31, 2010 | 10:36 AM
Pillsbry10's Avatar
Crane gold aluminum race rockers I think was the name, I bought those like three years ago, 1.6 ratio
Old Mar 31, 2010 | 11:09 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Those are the same ones I have. Through some headers on that motor to really wake it up. Never mind I see you already have a set.
Old Mar 31, 2010 | 11:34 AM
Pillsbry10's Avatar
I've had headers since before pacesetter started making them. They woke up the 3.1 so I'm sure the new motor will love them
Old Mar 31, 2010 | 05:35 PM
Pillsbry10's Avatar
Got a 4th gen throttle cable today, looks to be the right length.. Getting ready to go toy with it and see if it will attach to the pedal. If it does I'm going for a loud cruise through the neighborhood( no exhaust ha ha)
Old Mar 31, 2010 | 07:07 PM
Pillsbry10's Avatar
So the 4th gen cable fits perfectly with no modification
Old Jun 13, 2010 | 04:38 PM
joeyh2005's Avatar
Car: 92 Camaro RS And 91 Camaro RS
Engine: 305 and a 5.3L
Transmission: A4
well nice to know that you found a use for the 3.4 i had a 3.4 camaro it was a 4th gen with a 3.4 and i kinda hated it bc i couldnt really do anything with it but i see you have found something and did something with it best of luck with your engine
Old Jun 13, 2010 | 05:58 PM
Pillsbry10's Avatar
It's a pretty common swap for our thirdgens... Turbo install coming soon
Old Jun 26, 2010 | 11:47 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Sorry if this is a dumb question, but I've seen a ton of 3.4 swaps here so I was wondering how much power they put out? Yours looks great BTW!
Old Jun 26, 2010 | 11:55 PM
Shiv515's Avatar
Car: 1986 Chevrolet Camaro
Engine: 2.8L V6 soon to be 3.4
Transmission: 700R4 soon to be WC t5
Wow, looks really awesome man! I suppose this is what I'm eventually going to do. Just out of curiosity where did you pick up the motor and how much did you pay for it?
Old Jun 27, 2010 | 03:09 AM
Pillsbry10's Avatar
homestly i dont know how much it put out after it was put in, it needed a tune and now its getting a turbo put on. however my 3.1 put out 133hp and 178tq...so id assume a bit more than that.
the block i got from the junkyard cost about 550, but ive got more money in the motor than i can even remember now
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
92projectcamaro
Aug 6, 2015 01:20 PM
