New water pump and still running hot
Old Mar 7, 2010 | 09:11 PM
Formulized94's Avatar
Car: 2006 Chevrolet 2500HD
Engine: Duramax
Transmission: Allison 1000
I just purchased and installed a new pump on my 84 berlinetta tonight with the 2.8.
They pump was leaking from the bottom weep hole. Anyhow, I get it buttoned up and filled with fresh coolant. I start it and it runs for about 5 minutes and is at 220* on the cluster. I am guessing it is the thermostat, what do you guys think?
Old Mar 7, 2010 | 09:20 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: New water pump and still running hot
IDK if this applies to 3rd gen, but my '91 Blazer would show over 220* just turning the key and would have a hard time starting. Turned out to be some kind of temp sensor was bad.
Our Camaro doesn't have any ECM so IDK if there's one in 3rd gens or not.
5 mins driving or idling? Hoses feel hot?
Old Mar 7, 2010 | 09:27 PM
Engine: Duramax
lower hose feels warm and the top hose that goes to the thermostat stays cool. Also after it gets to that temp there is a ton of pressure on the system, but no steam.
If I let it run, it will peg the gauge at 260*.
I have not driven the car yet, I am afraid to. I do not know how fragile these things are to overheating
Old Mar 7, 2010 | 09:57 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
air in the system? thermostat is easy to change too. Siphon down radiator level until it's just below thermostat. Pull it off and see if there's coolant right there. Fill coolant up to top of hole, put new thermostat in, add a bit to radiator until it starts coming out around thermostat. Push down on plunger a little bit to get air out, put t-stat housing and hose back on, and fill radiator back up.
That's how I usually do it (a little pushing up and down on the upper hose too to work the air out of it), and I hardly have to add any once it warms up.
With a new pump and t-stat and all the air out of the system, if it still over-heats while idling, the fan isn't coming on (electric right?), there's a passage blocked, or the radiator core is plugged.
I can't think of anymore than that at the moment.
Old Mar 7, 2010 | 09:59 PM
Car: '87 Camaro
Fan(s) turn on?
Do you have a new thermostsat already, but not installed? I don't think it would hurt to put it in.
Gurus will have to chime in on this. IDK how to test the fan circuits // relays.
Old Mar 7, 2010 | 10:09 PM
Engine: Duramax
Fan(s) turn on?
It was a clutch manual fan car, but I have added an e-fan with a switch in the head and an over ride switch. No, the fan didnt come on though
I am going to put a thermostat in it tomorrow and bring my IR temp gun tomorrow and check the temp that way.
Old Mar 7, 2010 | 10:19 PM
Car: '87 Camaro
I see my EDIT didn't go...
coolrimsatleast makes a good point-- air pocket can cause a problem.
IR gun would be an idea!
Old Mar 8, 2010 | 06:10 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If that engine has a coolant temperature sensor (or some sensor or switch in the intake coolant passages), remove it and put coolant directly into the engine. Then fill the radiator and overflow bottle again. You have a MASSIVE air pocket right underneath the thermostat, which is why the sender reads hot after only 5 minutes. That's why I fill the engine first and then the radiator.
Old Mar 8, 2010 | 07:57 PM
Engine: Duramax
After I had heard about the history of the car(over heated quite a few times), I went ahead and replaced the thermostat. While I had it out, I filled the block that way. Oddly enough it took about half a gallon.
We drove it around tonight a little bit, put fresh gas and aired the tires up.
Thanks everyone.
Old Mar 8, 2010 | 08:50 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
if it's still running hot and when you accelerate it pings, check your timing...
Old Mar 8, 2010 | 09:10 PM
Engine: Duramax
Its all good right now, I am going to run it around in some day time heat and make sure.
It idled in the driveway for about 45 minutes with the fan cycling on and off. It didnt get to about 190 degrees via the ir gun.
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Mar 5, 2017 06:37 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
