WTF is the problem?
Old Mar 8, 2010 | 06:45 AM
89v6firebird's Avatar
Car: 89 firebird (v6) T-top.
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
WTF is the problem?
I was driving my firebird yesterday, because it was nice and warm out. i took it for a spin on some main roads, then decided to it the highway to open it up a little. Well when I decided to get off, i was on the offramp and the car just shut off. So luckily i was able to move it to the shoulder where I got it started again. This has never happened, it will usually stall when its cold out, and at a light or stop sign, but not while im ****in driving! So im gonna take it to my mechanic and see what he finds.
What you think it is? injectors? fuel pump?
Old Mar 8, 2010 | 06:06 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: WTF is the problem?
Wiring in the ignition system, ignition module or coil, vacuum leak... Those would be my main guesses.
Old Mar 10, 2010 | 12:28 PM
firebirdland's Avatar
Car: 91 ,82 trans am 79 t/a
ignition module
Old Mar 10, 2010 | 03:47 PM
tkemo648's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Check the fuel pressure, I just had my pump crap out on me today. Mine would run fine as long as you were cruising, nail the pedal and it would spit and sputter and eventually die. The car was just holding about 28psi of fuel pressure, gas it and the pressure would drop to around 20psi. The repair manual at my cousins shop said it should range from 41-47psi. I'm hopefully replacing mine this weekend.
pjsparts
Oct 29, 2025 06:39 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
