I'm on a quest to make my V6 a beast how can I do it?
Old Mar 15, 2010 | 05:48 PM
thizzlamich's Avatar
Car: 88 Chev Camaro
Engine: L05 V8 from 93 Caprice Interceptor
Transmission: 4l60 Auto
Axle/Gears: Stock ones limited slip i believe
Hi guys i'm new to the forum and I was wondering,
if you could help me
Ok so I have a
"Base" 1991 Red Firebird (just had it painted) it has the 3.1 V6 that's stock except a K&N air filter, I guess they stopped producing cold air intakes for the 3.1 or something because I can't find any..
But I was on youtube and saw 3.1's with I guess maybe installed posi and they were spinnin the tires no prob, when I first got it it would if I hit it right, i just about still can...But i just wan't to know what the best things to upgrade were to make it mean!!
What would you guys do?
Old Mar 15, 2010 | 06:05 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: I'm on a quest to make my V6 a beast how can I do it?
Ram air intake, 3x00 heads and intake, headers, and a good cat and muffler. Also more often than not those are stock or near stock v6s, they're just doing brakestands most of the time, but they're are certainly ones built enough to spin tires easily, just not very common.
Old Mar 15, 2010 | 06:06 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
read through all the treads at the top they will tell you pretty much all the stuff you can do to them
Old Mar 15, 2010 | 09:41 PM
Car: 88 Chev Camaro
Are all the links to everything your suggesting in the sticky up top??
Yeah and it's an auto trans as well, but I guess a question i'm asking is...it's possible to make the 3.1 noticibly faster if not much??
Old Mar 15, 2010 | 09:47 PM
Engine: 3.8, 3.4
Project89 has a turbo setup with god knows how much HP and tq, at very least 300-400 hp and 400-500 hp....on stock heads and manifolds, though I'm relatively certain they are ported, but nonetheless they won't flow as much as aluminum 3x00s do stock, not to mention the weight savings. But to answer the question, if you're willing to spend time and money yes, your goals and resources are what really determine viability though...if you want 800 hp, get a v8, the v6s haven't really been pushed to the limit, but I believe they can get 600, maybe 700 with the right setup and a lot of time, money, knowledge, and patience, no one really seems to know the limits on them, but I'm going to be one of the frontiersman on that regard...
Old Mar 15, 2010 | 10:08 PM
Car: 88 Chev Camaro
I hear you, and at the time my recources are a bit limited...What would you suggest starting off with? Maybe a ram air intake?
Also I can't seem to find one anywhere?? Oh and if I was to get a ram air is it necessary to get a hood with the louvers or would it still be functional?
Edit: And thanks for taking the time out to reply
Old Mar 15, 2010 | 10:12 PM
Engine: 3.8, 3.4
Well unfortunately you're not blessed with fog light tubes directly in line with a dual snorkel TPI intake(I think, I don't know firebirds that well) but in my case all I have to do is put a hole through the air dam and pipe in air from the fog light tubes to the air boxes. In yours the only surefire way that I know of is to get a ram air hood and go from there, but there is probably another cheaper way. Next best thing though would be headers/exhaust or ignition, after that you have to start getting deep into costs and removal of major components. Ie. 3x00 top end swap, cam, head/manifold porting, or boost, or block swap to 3.4.
Old Mar 15, 2010 | 10:24 PM
Car: 88 Chev Camaro
You are correct in saying so ,my bird only has the snorkel that curves round and down the passenger side...damn the v6 camaro's have those stock though?
Old Mar 15, 2010 | 10:25 PM
Engine: 3.8, 3.4
Yep. Or at least some of them do.
Old Mar 15, 2010 | 10:33 PM
Car: 88 Chev Camaro
Is the oem exhaust bad? I just got it replaced from the y-pipe back a couple months ago lol
Old Mar 15, 2010 | 10:45 PM
Engine: 3.8, 3.4
I wouldn't say its bad, especially for a non built engine, but mandrel bent stainless steel with a good muffler and headers never hurts.
Old Mar 15, 2010 | 11:07 PM
Car: 88 Chev Camaro
What are the best headers to put on the 3.1?
Old Mar 16, 2010 | 09:04 AM
Engine: 3.8, 3.4
There's really only one option I know of which is pacesetter, summit sells them for ~280 for painted ones or 500 some for ceramic coated.
Old Mar 17, 2010 | 12:22 AM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Two questions first:
1) What is your budget and,
2) What do you want to achieve?
Old Mar 17, 2010 | 01:15 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
1. Birds can't use the dual snorkel intake or the T/A would probably have it... Hood to radiator clearance is WAY too short for that. That's why you see all the birds with air intakes have the elbow going one way or the other at the radiator. Ram air intake requires a Ram Air hood. There are no off-the shelf air intakes for the ThirdGen Firebird. Everything you will see around has been custom made, pretty much.
2. Occasionally, Hedman and I think Edelbrock headers pop up on eBay. Don't get the ones for an S10... They have full frames and tons more ground clearance.
3. The OEM exhaust is horrible... The crossover pipe joins the pipe from the left side in a T instead of a Y. The stock cat, if you still have it, is like trying to push the exhaust through a wall.
I could spin the right rear tire (open diff ) with a cruddy running 3.1 auto with the brakes applied (and adjusted properly)... Kept up with a 4.3 S10 as well. But, then, I do have a 3.42 rear end ratio, and your 91 probably has a 3.23 rear gear...
Old Mar 17, 2010 | 06:03 PM
Car: 88 Chev Camaro
Well, Right now I wan't to know whatever I need to save up to get, some now, some later.
#2 I wan't to make it faster and more efficient for everyday day use, i'm not gonna hit the track...but still wan't it to go, this is my first firebird so I wan't to know what I can do in midst of just improving all around perf. in general.
Thanks For the Replies
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Dale
Aug 24, 2004 12:06 PM
pennylessz28
Nov 10, 2002 10:23 PM
KeithO
53
Sep 24, 2001 02:56 PM
