Thought I was dead? UPDATE on the IROC-Z
Old Nov 8, 2002 | 04:30 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
It's been awhile since I've posted, and I haven't been posting nearly as much as I was. I got caugth up with some things, and running the local Thirdgen group as well. www.hr3rdgen.org!
So to answer your question I'm not dead, nor is my alter-ego "pennylessZ28" but I'm not so pennyless anymore. I've been working a pretty successful job.
If you recall I once owned an 89 RS and I am the dude who wrote up "The Poor Mans White Face Gauges" later I got my hands on this puppy, the IROC-Z, just like I always said I was gonna get!
[img]http://www.mikekey.net/images/P1010003.jpg[img]
Then one horrible day in mid July this happened!
I only owned this beautiful car for one month. It was such an awesome car, big improvement over that LO3 POS.
Well I've been doing my own body work, and my front clip just came in today!
Here is the car currently:
The engine is basically unbolted and ready to be removed, I'm just waiting on a friends cherry picker.
PLANS CALL FOR THE IROC-Z Call for the following:
Scoggin Dickey Fastburn 385 Engine with LT4 Hot Cam Upgrade
Price: $4,900
Horsepower: 430 hp @ 6000 rpm
Torque: 430 ft/lbs @ 4400 rpm
Compression Ratio: 9.6 to 1
Duration @ .050" I/E: 218/228
Lift I/E: .525"/.525"
Block: 350 Cast Iron 4 Bolt 1 Piece Rear Seal
Crank: GM 1053 Forged Steel
Heads cc: Fastburn 62cc
Intake: GM Aluminum Dual Plane
I'm going to through on top of that the Holley Stealth Ram setup with holly TPI/LT1 Twin 58mm Throttle Body combined with Dynomax Cerama-Coat Headers 1/5/8'' to y-pipe which has an offroad pipe, straight 3 inch to flowmaster 60 series dual outs
Then we throw in my Accel Superstock 8.8mm Sprial Core Wires, Accel GM Remote Mount Super Coil and the Optima Deep-cycle Batterie Yellow top which I already own.
A little more tweaking....
Hotchkis Strut tower Brace
Be Cool Inc. Aluminum Radiator
Energy Suspension Camaro/Firebird Suspension Kit
Lakewood Rear Control Arms
Lakewood Coil Spring Traction Bars
Holly Adjustable Pressure Regulator
Elderbrock Aluminum Water Pump
Hypertech 160 degree thermostat
Aluminum Drive Shaft
Cross drilled and sloted Rotors
Perma-Cool Maxi-Cool Oil & Trans Cooler
and custom burned Prom and some tuning at the dyno
And for ****s and giggles!
NOS GM EFI Nitrous Systems T.P.I. Corvette, Camaro, Firebird; 100-150 HP NOS
Of course a brand new paint job New Carpet, and headliner along with some cup holders from a GTA if I can get my hands on them. After that my baby will be set and ready to rumble for Summer.
Wish me luck in quest to tame this beast!
Old Nov 8, 2002 | 04:45 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
It is people like you that make me happy. This is what the world needs. That car could be rotting in a junkyard, instead u are turning it into something incredible. GOOD LUCK
Old Nov 8, 2002 | 05:05 PM
un4givin89's Avatar
Thanx, the car has to much personal value to have been junked. I went all the ay to PA in that car and it was nothing but good to me in the short time it was drivable When I got hit, the car was still drivable, no frame damange, I drove the car home just the way you see it in the picture. all the damange was cosmetic mostly.
But when I had the front end off the car, I thought, why not just make it a project now! So now it is!
Old Nov 8, 2002 | 05:37 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Since i am such a LAMER, i'll only give you a bit of advice! If you order the crate motor and the hot cam seperate, do not buy the whole kit! All you need is the cam and the roller rockers. The springs in the kit are the same as the ones in the fastburn heads. You can save a little bit of money that way. I have already gone through this and trust me whan i say Scoggin-Dickey will not tell you that. I wasted some money, oh well. But, from the price you have posted, it seems like you are getting the motor and cam already assembled together. You could probally get away with ordering the stuff yourself and do the cam swap, its not hard at all! And you can re-use the timing gasket! All you would need is the lube. Well, good luck with everything-later.
Old Nov 8, 2002 | 08:42 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Kewl. Good to see ya back.
You havn't been around for a while.
Keep us updated on the car....
Old Nov 9, 2002 | 12:30 AM
un4givin89's Avatar
Yes the cam is already installed on the engine, I just want something with 0 zipo miles and brand spanking new to drop in their. A 502 would be nice, but its a few thousand more and just a few more extra things I don't want to do.
I left out the ford 9 inch I'd like to get ahold of with some larger gears
Old Nov 9, 2002 | 12:37 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Sounds like its gonna be a bad *** ride when you finish it up. What color are you gonna paint it?
Old Nov 9, 2002 | 12:48 AM
un4givin89's Avatar
Electron Blue
Old Nov 9, 2002 | 03:10 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Originally posted by un4givin89
Electron Blue
Hellz ya....
Old Nov 9, 2002 | 11:27 AM
un4givin89's Avatar
I went and snagged the front clip today!
HELL ya, here is what I paiud
Fenders, R& L 64.48
Front Clip 30.99
Total 95.47$
The hood I got from a friend, 50.00 bucks
Grand total 145.47 Not a bad snag huh
Old Nov 9, 2002 | 01:36 PM
SpeedJunkie's Avatar
Car: 88 IROC
Electron Blue
Thers is only one answer to that.......
:hail: :hail: :hail: :hail: :hail:
Old Nov 9, 2002 | 05:36 PM
ZRated85355's Avatar
You are going to have one bad *** car!! i cant wait to see it all electron blue!!!!! Im jelous.
Old Nov 9, 2002 | 05:52 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hmm... Electron Blue... correct me if I'm wrong, but is that not that really sexy blue available on the Z06 Corvettes?
Great color choice, and that motor will also have the ***** to back up the image
Old Nov 9, 2002 | 11:53 PM
johnyIROC's Avatar
Looks like you have come a long way from your "trick braking" days.
Old Nov 10, 2002 | 12:45 AM
un4givin89's Avatar
Yeah, i just need to go get the cherry picker from ZepherWS6 and get him to get his motor in his car so it will run for once, lol
She is coming along nicely.
Old Nov 10, 2002 | 12:49 AM
johnyIROC's Avatar
Why did you change your SN? Sick of the bad rep you got when you were a n00b?
Either way... sounds like a nice project.. and good to see you are doing the work yourself. I respect that.
Old Nov 10, 2002 | 01:31 PM
un4givin89's Avatar
"un4givin" was the name of the black RS, pennylessZ28 kinda fit and I was using it on AIM and everywere else becuase of the Z28 and the lack of a job at the time when I got it. Of course, now I should call myself plentyfulZ28
Old Nov 10, 2002 | 04:32 PM
BikertrashDude's Avatar
hey mike glad to see the car is coming along.......hows the gang over at hampton roads 3rd gen doing, I been to busy to be on-line any where, trying to get all the riding i can before the winter sets in, can u beleve it was in the 80s today?????
later
biker
Old Nov 10, 2002 | 05:43 PM
un4givin89's Avatar
Yes i know, itwas nice out, i lite the tires and drove the iroc minus the front end all over today. Str8 headers are loud as S*$#@
But it was awesome! Everyone is doing good, wondering why you haven't posted!
We have over 100 members now!
Old Nov 10, 2002 | 10:23 PM
MdFormula350's Avatar
looks great!!! alot of progress..... its going to be bad a$$ indeed...
Bubbajones_ya
Jul 6, 2024 08:32 PM
Johnoooooo
Sep 22, 2015 08:55 AM
Fronzizzle
Sep 8, 2015 12:10 PM
IROCZ1989
Sep 4, 2015 11:54 AM
andy74
Sep 3, 2015 08:41 AM
