anyone interested in some o2 sims or an fuel/ignition piggy back controller
Old Apr 7, 2010 | 09:34 PM
project89's Avatar
anyone interested in some o2 sims or an controller that can add or subtract fuel and ignition timming
the o2 sims will work on any car and are 30 bucks each + shipping which should only be 2-3 bucks\and are 3 wire hookup work with single wire threw 4 wire sensors
the fuel and ignition controllers are still under development and but will allow adjustment of fueling across the map of +/- 10% and the ability to reatrd or advance ignition timing -/+ 5*
testing should be done soon on the fuel/ignition boxes
please note fuel.ign controlers are not substitues for complete computer tunning but give u the ability to adjust to a point the stock tables or even the tables on a modified chip
Old Apr 7, 2010 | 10:23 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: anyone interested in some o2 sims or an fuel/ignition piggy back controller
How/what would a O2 simulator be used for?
Old Apr 7, 2010 | 10:28 PM
project89's Avatar
the o2 sims are used on 96 and up cars when the cat is removed or off road pipe is used,
without the cat the rear ( downstream) o2's will set of a check engine light so the sims just trick the ecm into thinking that the cat is there and working correctly
they are a lil useless on our cars but i figure ppl may have other cars that do need them
on the other hand i am building the piggy back controllers specifically for the 3rdgens
Old Apr 7, 2010 | 10:30 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Will the fuel and ignition controllers work in our cars? If they are cheapish I'd be intrested
Old Apr 7, 2010 | 10:37 PM
project89's Avatar
lol i edited my post after u replied and i figured u were going to ask that ?
yes i am building the piggy back controllers specifically for 3rdgens one for maf cars and one for speed density cars (v6) and v8 versions to follow.
think apexi afc except these dont have digital displays and the price will be far cheaper then anything available for what it does
Old Apr 8, 2010 | 01:13 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
If the price is reasonable, i would be interested in the fuel controller.
Old Apr 9, 2010 | 01:23 PM
project89's Avatar
incase anyone is interested in one of the 02 sims
here is what they look like finished
ill take some pics when i solder some more together so u guys can see the guts of it
Old Apr 11, 2010 | 09:06 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ye i what one for a 92 camaro v6 at tranny
Old Apr 18, 2010 | 07:14 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Updates on the fuel/ignition boxes?
Old Apr 18, 2010 | 11:10 PM
project89's Avatar
the maf circutry is giving me some fits so its slow going on those so it may be some time before i have a maf based controller ready but sd version is about ready to go
on the other hand ive figured out a way to get the sd cars to read boost using one of my controler but it does require burning a new chip with updated fuel tables
basically i can use a 3 bar map and cut the output signal down threw the controller.the map resolution goes down doing this but if i could come up with a chip to include witht he controler it be a pretty easy install for somone lookng for boost
once i get the maf circutry figured out and fixed i could basically extend the mafs useable airflow range as well
Old Jun 28, 2010 | 02:37 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Bump for updates?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Eric-86sc
Sep 28, 2015 11:37 AM
Dragonsys
Sep 25, 2015 03:51 PM
