keeps dieing???????
Old May 24, 2010 | 09:00 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Axle/Gears: Borg Warner 3.27
keeps dieing???????
bought it for #50$ dream car, had a bad distibutor.. replaced it now it isnty jumping time, but when i hold down the brake and stop.... put it in park or stop in N, sometimes it just dies???? idk why, but the egr valve was taken off but i was told that make no difference, and the cadillac converter was torn off. but idk why it keeps dieing? any ideas?
Old May 24, 2010 | 09:24 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Re: keeps dieing???????
Help us out with more info. Depending on how the EGR was removed, it could be your problem. Most likely a vacuum leak. Any codes?
Old May 25, 2010 | 03:27 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Could be a vacuum leak. My car was running all weird and I found a broken vacuum hose. Replaced all the hoses with new ones and no more problems...except for the injectors when I first start it. Your problem could be the fuel pump too my dads 88 s10 blazer did something similar to that and it wasn't getting enough fuel pressure at idle.
Old May 25, 2010 | 04:22 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Could be carbon buildup on your throttle body, bad fuel filter, air filter, spark plugs, do a full tuneup basically, then if its still doing it, maybe your ICM, fuel pump, o2 sensor, IAC or TPS.
Old May 25, 2010 | 04:58 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
didnt even think of carbon build up, but yea when i get im gonna have a full tune up done on it and i hope it solves the problem. THANKS for all the feedback.
Old May 25, 2010 | 05:00 PM
Engine: 3.8, 3.4
Yeah, my 92 lumina kept stalling out at stop signs, stop lights, esp ones going uphill, and it kept stalling out moment I would put it into gears too, was carbond buildup on the throttle body =/ Just get some carb and choke cleaner and clean it up around the plate.
Old May 26, 2010 | 01:30 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
it was carbon build up WOOT WOOT, its all cleaned out now, im so happy that i dopped a patch in front of the streator ambulance station.
Old May 26, 2010 | 08:24 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Good deal. I want to see a picture of your $50 Camaro!
Old May 26, 2010 | 08:50 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
ill get a pic of the firebird within the next day or to ok
Old May 26, 2010 | 08:52 PM
Engine: 3.8, 3.4
Yeah...$50 is a steal, I'm guessing someone you know just wanted to get rid of the thing, but even for a shell that's a good price, let a lone a complete and even running, car.
Old Jun 15, 2010 | 04:13 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
having some trouble getting a camera will post pics VERY SOON.
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
