Good used 2.8 internals
Old Jul 19, 2010 | 08:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Anyone got any used but good rods?
Only need 1 for the 85 2.8 Im putting back together for the S15.
Low mile engine with 1 spun rod bearing.
Once I pick the scab off the crank Ill just need a rod to slap it back together.
budget build, only replacing what has to be replaced.
Old Jul 19, 2010 | 09:00 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Good used 2.8 internals
ive got 3.1 rods, are they the same?
Old Jul 19, 2010 | 09:36 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Rods are the same but pistons aren't. Make sure you find a machine shop with the right equipment to press the rod pins. Anything that isn't behind a gas station should have it lol. I have rods with the pistons removed.
Old Jul 19, 2010 | 10:27 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I have exactly one pair of 2.8 pistons and rods without rings. LMK. I just pulled them out of the FWD mockup block 2 days ago and there is no damage of any sort on them. I'll even throw in the stud nuts and bearing halves.
:edit: Also, depending on how long the crank was turning without a bearing, you may need to either have the crank turned or slap in another one (have one of those as well).
Old Jul 20, 2010 | 08:08 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
I have a complete rotating assembly out of a 2.8L V6. Hell, I have the whole engine. Rotating assembly is in good shape. PM if interested.
Old Jul 20, 2010 | 09:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Pretty sure the crank will clean up easy, but let me take it the rest of the way apart first.
Well just the bottom end
Any bets on if Ill pull off changing the rod / pulling and reinstalling the piston from the bottom??? [aka no head gaskets to buy or vavles to F with
yes IM lazy.]
Old Jul 20, 2010 | 10:36 PM
bl85c's Avatar
Car: '85 maro
LOl look at all of us trying to unload our junk on him. It would be easy to pull it from the bottom & reinstall. I've 'repaired' motors that way after the jacket split on sparkplugs.
Old Jul 20, 2010 | 10:46 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
LOL! Yeah, I kinda feel bad, but, hey, if he needs something I got, that I don't need, why not? Oh, and the monetary compensation would be nice for me...
Old Jul 21, 2010 | 06:39 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
That crank will need to be turned for sure.
If everyone else falls through i have plenty of gen1/2/3 rods laying around. probably 20 or more.
Old Jul 21, 2010 | 06:08 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You could easily pull the crank out the bottom (duh), but the ridge in the cylinder will probably be too high within the cylinder for a reamer (not that you could get it in there through the piston assembly anyways). You may damage something trying to get it out the bottom, or even get the piston stuck if the ridge is bad enough.
TheExaminer
Aug 25, 2015 07:34 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
InfinityShade
Aug 22, 2015 08:00 PM
86Base
Aug 8, 2015 01:34 PM
