Ceramic headers on my 3.1?
Old Jul 28, 2010 | 12:59 PM
vaughnsfirebird's Avatar
Car: 1990 Firebird/1997 Ranger
Engine: 3.1/2.3
Transmission: Auto/Manual
Axle/Gears: 3.23/don't know don't care
I hear I have to do some extra fabrication to fit headers on my 3.1. Has anyone done this that can tell me what they've done?
Vaughn
Old Jul 28, 2010 | 05:50 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Ceramic headers on my 3.1?
it depends on which ones you buy, i had to remove my egr system and my AIR pump. i have a set of stainless ones if your interested
its not a hard thing to do
Old Jul 28, 2010 | 07:38 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Which headers are you talking about?
Old Jul 28, 2010 | 09:26 PM
Engine: 3.1/2.3
I'd like to be able to pass smog. Anybody passing calis smog test with headers on?
Old Jul 28, 2010 | 10:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Can't pass smog with headers because there is no fitting for the AIR pipe in the pass side header...
Old Jul 29, 2010 | 08:57 AM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
We're talking about the PaceSetter headers, right?
Old Jul 29, 2010 | 02:27 PM
Engine: 2.7L V6
Axle/Gears: 4.41
No 60* headers have the provision for the AIR system... A lot don't even have the provision for the EGR, depending on the age of the headers (PF&E, Hedman).
Old Jul 29, 2010 | 10:18 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Do you know whether or not the PaceSetter headers have the provision for the EGR hook-up?
Old Jul 29, 2010 | 11:32 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
My Pace-setters have the EGR provision. Im not sure if there is any difference between the ceramic ones or not but I have the non-ceramic ones FWIW
Old Jul 29, 2010 | 11:44 PM
Engine: 3.1/2.3
Hey man where did you get it? Or do you have a part no. I really want headers but I also want to pass smog here in Cali.
Old Jul 30, 2010 | 12:26 AM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Doesn't anybody use the "search" function anymore? In a previous thread, I posted my numbers on emissions testing four days after the install on a major build.
https://www.thirdgen.org/forums/v6/4...its-alive.html
So, YES, no AIR system (only needed when the engine is cold). YES, there is an EGR port on the right-hand-side of the headers.
Old Jul 30, 2010 | 11:42 AM
Engine: 3.1/2.3
I've read your thread and enjoyed it. Contests on your build. My problem is I don't know if I need the air pump or not to pass californias smog test seeing as the air pump originates with a hose coming from the smog pump. I'm going to go ask a local smog guy and bring results for any v6 guys like me in Cali.
Old Jul 30, 2010 | 12:13 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
http://www.partstrain.com/store/?PN=...universal:0%29
Got mine from Partstrain, they are cheaper then summit.
Old Jul 30, 2010 | 07:16 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You can't pass smog in CA with the PaceSetters. It says so right on their website, that the headers are only 49 state legal, with CA having said "No way, Jose!".
It appears that CA maintains that every car MUST have ALL of its original emissions control equipment to pass state emissions inspection.
Old Jul 30, 2010 | 11:58 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
But since the Pacesetters have the EGR on it then why wouldn't he pass?
If you do get Pacesetters GET THE CERAMIC COATED HEADERS. Trust me! The regular headers will rot out quick! They did on my camaro
Old Jul 31, 2010 | 02:20 AM
Engine: 3.1/2.3
Yeah the guy at the smog shop Said exactly that. Even the air injection system. If anyone finds carb approved headers for our v6, spread the word please.
Old Jul 31, 2010 | 02:53 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Seems to me you could modify the pacesetters to accept AIR?
It would need the tubes welded, but if you could do that I can't see why that would be a problem. I haven't seen it done on a V6 before though. Not saying it's practical, but it's certainly possible
Old Jul 31, 2010 | 04:25 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Axle/Gears: ?
even if u get air tubes on the headers have to be CARB approved for cali use. no CARB number automatic fail.
Old Jul 31, 2010 | 10:53 AM
That hasn't stopped anyone with "Dyno Don's" headers from passing though, his have no CARB number.
Old Jul 31, 2010 | 11:50 AM
Pillsbry10's Avatar
i think basically what everyone is saying is they arent "technically" legal to use in CA in most cases. if you get by with it awesome. its your choice but either way youll have to modify them in some way.
sailtexas186548
Feb 17, 2017 03:07 PM
redformula88
Oct 14, 2015 06:08 PM
cking99
Sep 22, 2015 11:33 AM
cstrobel65
Sep 16, 2015 11:54 AM
