3.1 L Headers
Old Aug 19, 2010 | 09:00 PM
joecool108's Avatar
Car: 91 Vert, 69 SS, 91 Coupe
Engine: V8, V8, V6
Transmission: Auto, Auto, 5 speed
3.1 L Headers
Does anyone make a header for a 90-92 3.1Liter engine? All I can seem to find is ones that fit 2.8 liter engines. Any suggestions will be helpful.
Old Aug 19, 2010 | 09:05 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: 3.1 L Headers
https://www.thirdgen.org/forums/v6/5...stainless.html
the 2.8 ones bolt of the same in most cases
Old Aug 20, 2010 | 01:04 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Re: 3.1 L Headers
The 2.8L headers will fit on the 3.1L V6 without modification.
Old Aug 20, 2010 | 02:06 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: 3.1 L Headers
This has been covered a hundred times, but for the record: the 2.8, 3.1 and 3.4 have the same heads and take the same headers. If you have smog requirements you have a problem in that the 2.8 headers are not certified for use on the 3.1 (in California where I am for example). You can USE them, but you will be flouting the law, you madman you. The 3.4 headers will bolt up, but since they are designed for the 93-95 4th gen, one of them has to be heated and bent to clear the frame from what I have been told...
If you want to buy them from Pacesetter, just tell them they are for a 2.8 and they will supply them, no problem...
Pacesetter told me it costs about $100,000 to get the CARB certification for a set of headers and there are just not enough of us driving this boat anchor of an engine to justify the expense.
Old Dec 31, 2010 | 07:58 PM
joecool108's Avatar
Engine: V8, V8, V6
Re: 3.1 L Headers
Well we are currently installing these on our 3.1L and are running into problems, the rear bracket that holds the alternator now wont work, and on the driver side the p/s lower bracket wont work. Oil Filter touches one of the tubes and the clutch line is close to the tube, from what I can tell it is plastic..... YIKES!!! Now what! Any suggestions will be helpful
Old Dec 31, 2010 | 08:02 PM
Pillsbry10's Avatar
Re: 3.1 L Headers
pics?
Old Dec 31, 2010 | 08:11 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: 3.1 L Headers
Thread deviation for just a moment! Pilsbury have you talked to project89 recently? he hasn't been on in quite a while. I hope he didn't ditch this site again because of a little razzing on his thread. Sorry for the takeover.
Old Dec 31, 2010 | 09:57 PM
joecool108's Avatar
Engine: V8, V8, V6
Re: 3.1 L Headers
well ive searched through and most people have left that rear alternator bracket off and I think I can modify the p/s bracket to work. This car has a/c too. I also read where the 2.8 uses a shorter oil filter than the 3.1 so that may cure the problem. Now the last thing is the clutch line from the master to the slave.. why did they make that out of plastic!!!!!
Old Dec 31, 2010 | 11:51 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: 3.1 L Headers
I put the 2.8 headers on my 3.1. I left the alternator bracket off. I used to peices of all thread and some lock nuts to use the power steering pracket. I use a K&N oil filter which i think is the longest available and it clears no problem, thouth it is closer then I like.
Old Dec 31, 2010 | 11:53 PM
Car: 1990 Camaro RS
Re: 3.1 L Headers
I modified the alternator bracket to work at one point. I ran it for awhile then took it off when I had the alternator out and didn't re-instal it. I have been running it that way for 6+ months.
Old Jan 1, 2011 | 08:44 AM
joecool108's Avatar
Engine: V8, V8, V6
Re: 3.1 L Headers
I need a shorter oil filter, the one that is on there is too long. Its a purator, the one that the parts book reccomends. Any ideas on the hydraulic clutch line?
Old Jan 6, 2011 | 07:41 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: 3.1 L Headers
Check out Summit and order an oil filter relocation kit. Relocate it to the inner fender or firewall away from the headers. Simple. And get your headers coated to cut down on the heat...
Old Jan 26, 2011 | 10:07 PM
1957pistol's Avatar
Car: 57 chev 2dr sedan - 57 chev 3100
Engine: the car is a 350 the truck is a 383
Transmission: both turbo 350s
Re: 3.1 L Headers
I have some for sale in classifieds.
Last edited by 1957pistol; Jan 26, 2011 at 10:09 PM. Reason: wrong thread..with two pages open sorry
Old Jan 26, 2011 | 11:17 PM
alexdavis001's Avatar
Car: 1989 camaro
Engine: 383 roller
Transmission: 5-speed
Axle/Gears: posi 373
Re: 3.1 L Headers
http://www.hawksthirdgenparts.com/pa...beheaders.aspx
Old Nov 22, 2013 | 07:46 AM
NeedMorePower!'s Avatar
Re: 3.1 L Headers
Did you get this done yet? if so did it work and around how much did you end up spending with the needed mods to make it work?
Old Nov 22, 2013 | 11:33 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 3.1 L Headers
When I had the Pacesetter headers on mine, i didn't reuse the P/S and alt brackets, and just run the shorter oil filter (for the 2.8) and you will be fine. I never had any issues with the clutch line on mine interfering. You don't need to relocate the filter, although it does make changing it easier...... don't do it hot lol. I was one of the first few to get those headers on here and ran them for years without any sort of issues with fitment or clearance.
Old Nov 23, 2013 | 04:15 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 3.1 L Headers
Bottom line:
Both alternator AND power steering rear brackets CAN be installed if you use studs and weld nuts on them in the proper places. Also, the rear power steering bracket has a bolt that goes into the engine block if you prefer not to use a stud in the header bolt location.
I use a PF52 (longer PF47) on my engine without issues. But I did wrap my clutch line in heat wrap because the lower end of it and the front of the slave cylinder are literally 1/4" or less away from the primary tube.
Elephantismo
Feb 13, 2019 12:51 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
redformula88
Oct 14, 2015 06:08 PM
cking99
Sep 22, 2015 11:33 AM
