more pep frm my 3.1
Old Sep 24, 2010 | 04:08 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
more pep frm my 3.1
ok guys so im looking to get some more pep and power out of my motor i was wondering what you guys would recommened w.o. spending to much money right now .
Old Sep 25, 2010 | 12:04 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: more pep frm my 3.1
This question gets asked at least once a month, and has been throughly answered many times..
If you're looking for just some simple things and bolt ons, there's headers, catback, 1.6 rockers, underdrive pulley, AC delete. More advanced you could get a cam and do some head porting. If you've got knowlege and money you could turbo or start a hybrid..
Old Sep 25, 2010 | 12:24 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
stroke that motor out! People have done it to V6s before on this site.
Old Sep 25, 2010 | 01:11 AM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
Ok I forgot to mention I have under drive pullies, catback, gutted cat .. was thinking headers but they don't do to much do they ? Also what exactly would doing the 1.6 rockers do ? Nd I was looking at a cam setup but wasn't to sure what to go with .
Old Sep 25, 2010 | 01:20 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
It's a 3.1 not a 2.8, if he had a 2.8 then he could stroke it to a 3.1, otherwise I don't know of any setups that can stroke a 3.1, 1.6 rockers have the same effect as an aftermarket cam, more lift on the valves, and headers do as much as the rest of the exhaust combined, especially since the stock exhaust has a crappyass t-junction in it, if you get pacesetter headers they come with a Y-pipe, cam wise a 260 grind is a good choice if you do supporting mods, but its a bit of a higher powerband.
Old Sep 25, 2010 | 01:25 AM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
Ok so I can do the rockers with no other internal work and it will actually help me out and give me more power ? Also the headers your talking about are the ones for the 2.8 correct ? And its direct bolt in no modifications .
And thanks a lot guys I really appreciate the help.
Old Sep 25, 2010 | 01:44 AM
Engine: 3.8, 3.4
Headers I believe bolt right up to either engine, check summitracing for that, rockers if they are stamped steel non rollers should fit under stock valve covers(as far as I know) if they are roller tips, roller fulcrums or full rollers I believe they will not fit unless you get fiero valve covers.
Old Sep 25, 2010 | 10:25 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Yes, the Pacesetters will bolt right on. Only if you remove the AIR pump and find a way to plug the AIR inlet at the catalytic converter. Which means that you can't do this in California (the only state that said NO to the Pacesetters being smog legal).
Old Sep 25, 2010 | 10:48 AM
[quote=3rd gen RS;4685140]It's a 3.1 not a 2.8, if he had a 2.8 then he could stroke it to a 3.1, otherwise I don't know of any setups that can stroke a 3.1quote]
I think I have heard about some people who had stroked them out to a 3.4 before though. Oh well maybe it is just my imagination!
Old Sep 25, 2010 | 11:04 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Umm... 3.4 has the same stroke as a 3.1 and the 3.1 can't be bored out that large without possible major block damage.
Old Sep 25, 2010 | 01:03 PM
Engine: 3.8, 3.4
Old Sep 25, 2010 | 08:10 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Or you could do this.
Old Sep 25, 2010 | 08:39 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
https://www.thirdgen.org/forums/powe...wer-added.html
Some info I posted on that thread to another new guy might be useful to you.
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
gta90
Sep 15, 2015 04:00 PM
the_nikfive
Aug 11, 2015 02:46 AM
