1991 V6 engine decision
Old Oct 24, 2010 | 06:33 PM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
I currently have a 1991 camaro rs and not quite sure what to do with the engine. I have 240K miles on it and i drive it everyday to work. I love my V6 its a daily driver and cruiser (Highway ~ 26 mpg cant beat it)
Should i just rebuild the V6 i have... ?
Or should i look to find a crate motor ready to go?
Any help or suggestions would be greatly appreciated.
Old Oct 24, 2010 | 07:22 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: 1991 V6 engine decision
is something wrong with it? if not drive till it breaks...keep it tuned up and the oil changed and you should be good
when it goes you can either rebuild the v6 or get a 3.4L v6 from a yard to rebuild, either one will work out good for you
Old Oct 25, 2010 | 01:29 AM
KG427KG427's Avatar
Car: 1991 camaro
Only problem about a rebuild is that might take awhile (weeks) and i dont have another car, and i heard a crate motor is cheaper and easier. Im going to drive it until it dies i take real good care of my car oil change, spark plugs, already put a new transmission, alternator. i should be good until i reach 300k but just want to start doing some research and any help would be nice.
Just dont know where to find a good crate motor that is reliable
Old Oct 25, 2010 | 07:41 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Crate motors aren't made anymore to the best of my knowledge, well not for our v6 F-bodies anyway, you could probably find some 3.4 crates, but expect to pay over a grand, imo, you should find another 60/6 engine used, and rebuild that, so that it's ready to go in, when your current engine kicks off or you are ready to swap at least. And not sure if you care about hp or not, but if so I would opt for the 3.4 swap.
Old Oct 25, 2010 | 01:24 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
you can still buy rebuilt engines, usually shortblocks aren't too expensive. Check your local auto parts stores, they can usually get them.
If you have all the tools and equipment that swap could be done in a day or less.
I agree that a 3.4 from a 4th gen would be a good alternative although most of them are going to have 100K+ miles on them by now. If you can find one for cheap enough it might be worth it to throw in all new bearings, gaskets, valve seals and a new cam/lifters with a good timing set.
Old Oct 25, 2010 | 01:27 PM
Engine: 3.8, 3.4
purple, have you finished your 3500 swap yet?
Old Oct 25, 2010 | 01:31 PM
Engine: 450HP 355
Transmission: TH350
Pretty much, it needs plug wires, fuel lines hooked up and fluids. I'm just finishing up another swap in a different car, '02 3400 into a 91 Cavalier. Once i'm done shaking it down the Camaro will be pushed back in the garage and finished up.
Old Oct 25, 2010 | 01:59 PM
Engine: 3.8, 3.4
You're putting the cavvy first?!?! shame on you!,lol. Really am surprised though, I would finish the F-body first if it was me...not to say cavliers are bad, just that camaros are better :P
Old Oct 25, 2010 | 02:05 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
if you aren't for a powertrain upgrade, then you should hit up one of the pick ur part yards and get yourself an engine, don't know if it's the same where you are as it is here in California where we get 50% off days and if it's raining we get a 25% off discount, just not combined ... you could easily pick up an entire engine with FI for about 150 or so with the discount... get that engine rebuilt and have it ready to go.. however, i don't know what the shelf life would be on that engine, so you'd probably be better off swapping it as soon as you had the downtime for the swap...
edit: lol.. you're in Los Angeles, you should have a pick ur part or something similar near you... they're all over the place...
Old Oct 25, 2010 | 02:31 PM
Engine: 3.8, 3.4
Engines can sit for a while(years) if done properly, ie covered in plastic, oil on all the necessary parts and places(prevents stuff from rusting), without coolant in it, though it is still better to just put it in use right away.
Old Oct 25, 2010 | 03:56 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
the oil part explains why when you go get something at the auto parts store it's all greasy... learned something new today...
Old Oct 25, 2010 | 03:57 PM
Engine: 3.8, 3.4
Yep, brake rotors are a good example of that.
Old Oct 25, 2010 | 08:48 PM
Engine: 450HP 355
Transmission: TH350
Had to finish it ASAP, it's sold and the new owner is coming up next weekend.
Old Oct 25, 2010 | 09:14 PM
KG427KG427's Avatar
Car: 1991 camaro
i got a price of $2800 to rebuild my v6 :/
rather buy one ready to go and i know a guy who will do the swap over the weekend.
Old Nov 4, 2010 | 07:18 PM
KG427KG427's Avatar
Car: 1991 camaro
anyone know any online sources for a 1991 camaro v6 3.1 engine
Old Nov 4, 2010 | 10:52 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
car-part.com or lkqcorp.com
Old Nov 5, 2010 | 12:27 AM
cj92firebird's Avatar
Car: 92 Pontiac Firebird
Engine: 3.1L FI
Transmission: Borg Warner T5
Axle/Gears: Stock 3.42
I rebuilt mine for under $600 that includes paint, and fluids. I did all the work myself though.
Old Nov 7, 2010 | 02:18 PM
KG427KG427's Avatar
Car: 1991 camaro
damn that would be nice 1200$ would seem like a steal.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
aharvel50
Sep 21, 2015 07:31 PM
amcnellis
Sep 16, 2015 04:16 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
