Slight knock on start up
Old Oct 28, 2010 | 03:17 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
I've noticed that if I don't start my car for a few day's when I go to start it up it make's a knocking coming from what sounds like the top of the engine for like 10 seconds then it goes away, after that I just hear the noisy lifter tapping away. I believe I have 2 bad lifters one makes noise at idle slightly and the other makes a louder tap when given acceleration. Could the lifters make the slight knock on the top end when it starts up?
Old Oct 28, 2010 | 03:43 PM
project89's Avatar
Re: Slight knock on start up
what brand of oil filter are u using? prolly dosent have an anti drain back valve
Old Oct 28, 2010 | 03:50 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
I second that. Don't get cheap oil filters or cheap oil changes. They pay for themselves in the long run.
Old Oct 28, 2010 | 04:10 PM
Car: 1988 camaro
Engine: cammed 3.1
I'm using a fram oil filter
Old Oct 28, 2010 | 04:15 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Which one? I like the tough gaurd ones, but not the extra gaurd ones. The extra guard do not have an anti drain back valve in them.
Old Oct 28, 2010 | 04:18 PM
project89's Avatar
id stay away from the fram filters, i personally wont put anything but a delco filter on mine, the only exception would be a remote mount canister filter if i ever decide to put one on
Old Oct 28, 2010 | 04:20 PM
Car: 1988 camaro
Engine: cammed 3.1
I'm using the extra guard filter, I'm guessing I should replace the oil filter then? Also now that I have a thread going, When I replace my lifters I want to do a cam swap and was looking at this one http://www.summitracing.com/parts/MEL-CL-MTC-5/ I would just like to get a little more torque out of it. Would this be a good choice for that?
Old Oct 28, 2010 | 04:23 PM
project89's Avatar
its a decent cam, but contact these guys
http://deltacam.com/
cam and lifter set is 105$'s shipped i belive
a popular cam is the 260 grind from them
Old Oct 28, 2010 | 04:27 PM
Car: 1988 camaro
Engine: cammed 3.1
Thanks I will be looking into that for sure that's a pretty good price.
Old Oct 30, 2010 | 06:12 PM
cj92firebird's Avatar
Car: 92 Pontiac Firebird
Engine: 3.1L FI
Transmission: Borg Warner T5
Axle/Gears: Stock 3.42
Thats the cam I put in my engine that is still getting put back together so I can't tell you how much it gave me but I can tell you if you order that same cam from Autozone you will save about 60 bucks. It is 116.99 at autozone.
Old Oct 30, 2010 | 09:08 PM
Car: 1988 camaro
Engine: cammed 3.1
116 doesn't sound too bad, I'm going to try delta cams and with the camaro and for my fiero I'll probably end up trying the Melling M-Select camshaft.
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
