throttle body
Old Dec 20, 2010 | 07:33 PM
TheSwarm666X's Avatar
Car: 1988 firebird
Engine: 2.8 V6
throttle body
there is two pipes for vacuum lines on the bottom of the throttle body.
what are they called and where do they go?
i tried looking for the information but i can't find it. sorry for the novice question haynes just tells me to make note on all the lines when i disconnect them and i can't find the info by the search bar, and i got the car with out some things and other things going to wrong spots and bypassed to arias that make no sense.
Old Dec 20, 2010 | 08:13 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: throttle body
If you are referring to the bottom of the throttle body, those are coolant lines put there by GM to keep the throttle body from freezing up. If you are talking about the big one near the top, that goes to the big plastic vacuum tree in the back of the engine. The metal tube that looks like accordion shaped is your EGR feed line that feeds exhaust gasses back into the intake stream. The only real vacuum connections are the large plastic line and the smaller plastic lines near the IAC valve that feed everything else.
Old Dec 21, 2010 | 08:37 AM
Car: 1988 firebird
Engine: 2.8 V6
Re: throttle body
ya, the coolent lines. where do they route to? also could i get a picture of your throttle body? from your reply i am now thinking other things might be different.
Old Dec 21, 2010 | 12:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: throttle body
your in Florida and reguardless of recent weather, you don't need it
#1 thing folks unhook on purpose.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
